KickAssCop
- Mar 19, 2003
Simple question
What AMD needs is a cut down version of Nano, maybe Nano Lite that has 80% of it's performance with an even lower TDP priced at $300. It would effectively kill off 970 GTX and would interest a ton of people. .
How's it going to "kill off" a 970 at 80% performance when it's not much faster at 100% performance? OC the 970 and it gets even uglier.
I'm almost certain that overclocked ITX GTX 970 is going to be cooler and quieter.I will end up getting 2 of these for my daughters builds but going to wait a little while and see if the price comes down some. The only real complaint I have is the price, but I guess I cannot complain to much because people are doing the reverse with the gtx 980 ti. You are paying for the fastest in its size bracket. Yes you can overclock the cheaper one, but you pay for it with the added noise and heat.
The poll is simple and made in an AMD forum. No comparison to the 970 required since different performance and price points. Also the only issues that are being made are by you. Everyone else is having a civil conversation.This thread and poll are pointless. It's a niche product, with an extremely limited target audience.
Where is your thread about the itx sized 970, or any variety of sff case that has a max card length?
This is a thread started by a guy who has said outright he won't buy any amd products, and thinks they're a shitty company. Why don't you fuck back off to the Nvidia section instead of trying to make issues here.
It's a tough choice between the Nano and the 970 for me, but I'll be getting a 970 this month.
I had considered a Nano for my ITX system, I'm certainly limited in space. While the Nano does offer the best performance in it's form factor, the price is just too high.
Priceerformance is top, secondarily it'll be working with a 4K TV over HDMI 2.0.... If the Nano was more like $450, I'd be all over it, instead of the 970.
quoted removed post .
Digital Foundry saw up to 30% faster performance than 970 GTX at 1440p so a lower TDP card at 80-85% of the performance of nano would put it in line with a stock 970 GTX, maybe even a bit faster. At the lower wattage (assuming it would have a similar cooler), it would have some more wiggle room for overclocking as well. Not up to 970 standards but enough to sway people over to the AMD side. My use of "kill off" was obviously greatly exaggerated but it would give it ample competition.
Considering that the performance is almost directly between a 970 and 980ti, the nano should be priced some where in between. If it was $450 I would get it and that was my plan when I heard about it. At $650 I would find a slightly bigger case and get the fury X or if I was obsessed with going as small as possible I would get the mini 970 since it would run cooler and quieter plus give me HDMI ports. There is no situation that I would buy the Nano at its current price.
I really think $500-$550 was the sweet spot for this card.
The 390X covers the $400-$500 segment pretty well (even though not mini ITX).
Also Tom's (ugh) is the only site that tested against an overclocked 970 ITX (I didn't see where they disclosed what speeds they OC'd it to however). At 1080p there is negligible difference between an OC 970 ITX and a Nano. Everything appears to be playable at or above 60fps on both cards at max settings on almost every game.
At anything above 1080p the Nano destroys the 970 ITX OC (between 5-50% at 1440p).
But we are also comparing $290 to $650 as it stands right now.
No, because I value money enough to not wish to flush it down the toilet buying low quality products at luxury prices.
Great little hardware.
Totally wrong pricepoint.
My current verdict= no.
You're kind of cherry picking 1440p, but I doubt many people are running 1440p in their living room.. But as long as we are cherry picking, Nano couldn't keep up with 980 even at 1440p in several benches, Witcher 3 for example.
More importantly, how about 1080p, which is the res of the majority of HDTV's that people would be likely to drive with a SFF/HTPC? That's where it falls down. So an OC'd 970-ITX could be on par with the Nano or very close at that res. For half the price, cooler and with less noise.
The only thing the Nano will be killing off is AMD.
