Are there any technical advantages to the new type-C front panel connector standard?
Jedibeeftrix
i.e. will it always provide a performance floor above that which could be assumed on previous USB 3.x motherboard headers?
e.g. assumes a minimum data-rate of 10Gbps (rather than the possibility of supplying only 5Gbps)
e.g. assumes a minimum power delivery of 18W (rather than the possibility of supplying only 5W)
e.g. allows a possibility to supply network over USB (which is something that wouldn't be possible from USB 3.x headers)
e.g. allows a possibility to supply video-out over USB (which is something that wouldn't be possible from USB 3.x headers)
Curious if there are any technical advantages over and above a nicer connector that is easier to plug in...
Thanks. JBT
kaaoszx
off the top it supports more bandwidth. So whatever chip/device is inside can take advantage of higher speeds. and With 4 data lanes, USB 3.1 Type-C can even carry DisplayPort and HDMI video signals, I'm assuming the wattage standard for power delivery means it can also fast charge smart devices.
kaaoszx
another important thing I just looked up.
Forenote: USB 3.0 was renamed to USB 3.1 Gen 1
a hub, the controller is the part that defines the usb protocol (and therefore speed) which it supports. The connector which can handle USB 3.1 Gen 1 (5Gbps) is identical to one which can handle USB 3.1 Gen 2 (10Gbps). The difference is which version the controller on the port supports.
The USB 3.1 Gen 1 hub has the same connectors as a USB 3.1 Gen 2 hub, but the controller is different.
ZzBloopzZ
Oh wow, good to know. If I upgrade to a new mobo, can I use my old cases USB 3.1 Gen 2 header for the front USB 3.0/3.1 Gen 1 to use as USB 3.0? Meaning is it backwards compatible?
Jedibeeftrix
I've read elsewhere that an old-style USB 3.1 (10Gbps) m/b header will work fine on a old-style USB 3.0 ports on a case.
Re: the advantages of the new-style header -
Is this all possibilities, or are there any headline upgrades you can [always] expect from the new-style headers?
i.e. always get a minimum of 10Gbps
i.e. always get a minimum of 18W
etc
BinarySynapse
No. Having a USB-C port does not guarantee any additional capability over USB Type A ports. It depends totally on what features are provided by the controller it’s connected to.
As an example, heres what the manual says about my system’s rear USB-C port
NOTE: The Type-C port only provides the USB data function, and no alternate video or Thunderbolt mode features are supported.
Epos7
I think the OP is asking about the USB motherboard header, not the USB ports themselves.
The new motherboard header is 20-pin (I think 40-pin versions with twice the bandwidth also exist) and is referred to as a type-E or type-A header. The old standard USB 3.0 motherboard header is 19-pin.
I think the new header allows for more bandwidth, regardless of whether you connect it to a USB-C or USB-A port. USB's naming scheme is so confusing however it's hard to say for sure.
BinarySynapse
Whether the OP was talking about the actual port or the header it connects to doesn't make a difference to what I said. From the point it leaves the controller it's all just wires connecting to each other. There's still no guarantee that any given feature of USB-C will be available other than a basic link (and that doesn't even have to be USB 3.0)
pendragon1
yup usb-c is just the connector style.
Epos7
Rereading the OP's post, I think they were asking about the port so it's correct that there isn't an advantage to USB-C.
However, for motherboard headers the new standard offers more bandwidth. It's USB 3.2 Gen 2. For example, from the Asus ROG Crosshair VIII Impact manual:
The old style header is referred to as USB 3.2 Gen 1 and can transfer at up to 5Gb/s.
The new style header is USB 3.2 Gen 2, sometimes called the USB-C front panel header. It can transfer at up to 10 Gb/s.
pendragon1
Rereading the OP's post, I think they were asking about the port.
and those speeds are dependent on the controller behind the connector. the header itself doesnt up the speed.
Epos7
In that case I'm confused. Why wouldn't motherboard manufacturers just use the old header and offer faster speeds on it? Surely that would be easier than switching to a new header.
BinarySynapse
The signals are slightly different for USB-C.
the 19-pin header has signaling for two superspeed channels, two USB2.0/1.1 channels, and two power pins . It’s intended to supply two Type-A ports.
The 20-pin header adds two configuration channels, two side band channels, and an additional power pin but has only one USB2.0 channel. It’s intended to supply a single USB-C port, and would only be able to correctly supply a single USB Type-A port.
USB-C can offer higher per port speeds through link aggregation, but it’s most important benefit is a that it’s a single reversible connector ( no more A/B/mini/micro Schrödinger’s crap) that is flexible enough to utilize many alternative signaling protocols.
Jedibeeftrix
thank you all.
so it appears that the new motherboard connector does not mandate any level of performance beyond the minimum that might be expected of the old style connector (even if it does offer the potential of greater performance).
Whether that be:
1. data-rates
2. power delivery
3. alt modes
just as an FYI on where i'm coming from:
It would be nice if every device using the new header [had] to offer at least 5Gbps (even if it offered 480Mbps also)
It would be nice if every device using the new header [had] to deliver at least 15W of power, to enable 3.5" external drives to be bus-powered.
It would be nice if every device using the new header [had] to enable displayport alt mode (not bothered by this one, just providing an example).
Ready4Dis
thank you all.
Whether that be:
1. data-rates
2. power delivery
3. alt modes
The new header? I can't think of any implementation.that uses the new header and doesnt have at least 10gbps and have there currents... That said they still aren't that popular and you mostly find gen 1 headers. Check out the line of x570, very few offer a gen 2 header. Now that doesn't stop someone from putting a usb-c connector on an old USB connection for ease of not needing adapters, they are backwards compatible. So if it's using the new header (not just the new connector) it will support gen 2 speeds and power. If it's just the USB c connector attached to the old gen 1 header, it won't. I went through this while finding boards for my son's h510 case that uses a gen 2 header for the from usb-c... Apparently, almost all MSI b550s have this. Almost no x570s have this.
swingdjted
What cases would have front USB connections that would match up with the Crosshair VIII headers?
Nobu
Fwiw, the 3.1 gen 2 header is a type-E USB3 connector. Knowing this might make searching easier, if the search engines would stop assuming you meant "type-c"...
Edit: Type-E, not F...
criccio
Fully Equipped
swingdjted
OK. I completely understand what each is and what it does, EXCEPT:
What does each header look like an a motherboard so that I can choose an appropriate case to compliment the motherboard?
I know what USB 2 headers look like.
I'm reasonably sure I can identify a common USB 3 (now called 3.2 gen 1) header, even though due to aesthetics, the headers on the mobos are rarely blue anymore even though they should be. They're annoyingly wide, but whatever. I am also familiar with USB A vs. C shapes.
I even think I might know what a 3.2 gen 2 header looks like. Back to reasonably narrow compared to the gen 1.
Now, what does it look like if a motherboard supports 3.2 gen 2x2? Is there a different header, or does it look like the regular 3.2 gen 2 header? Do motherboards even have 2x2 headers for case-front connections? And do cases on the market have the ability to do 2x2 on the front of the case? Or does a case front gen 2 automatically become 2x2 when a mobo supports it?
Finally, do any devices on the market actually have advantages associated with 2x2 when compared to regular 3.2 gen 2 or are we just waiting to see something happen in the future? If not, would it just be better to leave it all alone until USB4 [I even remembered to leave the space out between the B and 4] hardware becomes common?
I ask all this because I really want to get a computer case that compliments my motherboard (x570 ASUS Crosshair Hero VIII). What would a case need on the front to support what my mobo has in terms of headers?
It seems like all the information online points to that chart that is posted above. While extremely helpful, it does not address the mobo headers and whether or not 2x2 gets different hardware/wiring/headers.
Nobu
Here ya go, tom's got ya covered.
Don't think a two port 3.2 gen 2 header exists or is planned. A second header would work just as well, and most motherboards have a rear type-c port you could hook a hub to if two ports aren't enough.
TheSlySyl
I just used that new USB-C header on a Fractal R7 I built for a friend. Motherboard was an ASrock X570 Taichi.
BlackDragon1971
Jedibeeftrix
haha, new this discussion would generate interest in the end.
my X570 tomahawk has a USB internal header, where my Gigabyte B550 ITX does not...
