Are there any advantages of an AMD igpu?
ZodaEX
Are there any advantages of an AMD igpu these days over Intel's igpu?
I've been reading everywhere that the encoding quality of Intel's Quick Sync is higher than AMD's equivalent, and now the new XE igpus are faster in gaming too. Is there any reason at all anymore to go with one of AMD's igpus?
pendragon1
yes, for games. yes intels encoding is still faster. the xe mobile chips seems to be close to ryzen 3000g series in games, not faster(not sure where youre seeing that), but desktop is still far behind.
Shadowarez
for a test bench very handy when diagnosing parts. always nice to have a gpu you can test against. the new ryzen 5000 apus are coming but from what iv heard they still use vega graphics.
Domingo
If you have an Intel 9 or 10-series iGPU, you have the one PC setup capable of legally playing UHD Blu-Rays. Intel dropped SGX with newer chips and previous versions were too underpowered to actually play them without skipping like crazy.
bwang
Only the top trims of Xe are comparable to the (old) Vega IGPU. AMD also has much more reliable driver support - since their IGPU is just a tiny version of their discrete card it is pretty much guaranteed that any game will run on an AMD APU, albeit slowly. Intel's gaming support is getting better but its still going to be spotty.
crazycrave
AMD can get more performance with 5000series IPC gains and higher memory speeds with Vega as they kept it around for a reason . It's like seeing GDDR4 video cards evolve
Dew
I can think of one. You can actually buy the intel ones.
crazycrave
I would think memory speeds .. AMD should support up to 4000Mhz and that is the speed of the igpu if it runs at 1 to 1 with a 5000 series cpu .
