Don't bother with 10k or 15k on a laptop. That will needlessly drain the battery, and propvide only a small improvement over 7200 rpm. Those are built for dense servers, not low-power laptops
How old s the laptop? because you really have to go back ten years or more to not have support for SATA2. And SATA2 (3.0 Gbps) is plenty for an SSD to benefit you.
I'd look for the SSD with the best QD-1 random performance as I doubt that would even saturate Sata 1 speeds. Shame an optane solution wouldn't work, that'd be quite an interesting solution
https://www.cnet.com/products/hp-20...ws-8-64-bit-4-gb-ram-320-gb-hdd-series/specs/
This spec page says Sata 300.
If performance is an issue, a faster hard drive will only do so much. That AMD Brazos 1.3 ghz s terrible. It was barely a deal at 250."
Can't say for sure, I honestly get a bit too confused about all the SSD jargon to trust myself to make you a recommendation. I would just be mindful of low QD metrics as they are moreso what affects everyday user workloads and should not be bottlenecked by your sata II interface.I forgot I need 300 GB's.
What's a good QD-1 performance # for SATA 1? >70?
I told you, all Brazos systems support Sata 2. And that will certainly get the most out of an inexpensive drive like the mx500
I was thinking along the lines of this:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820226875&ignorebbr=1
For a good value I would look towards Microcenter's house brand 480GB SSDs. Not the best perf, but I doubt the Muskin one would be either. Does seem to fall behind in QD-1 perf though.I was thinking along the lines of this:
ive seen that too. no matter what its connected to a ssd will always be faster.Shoot, I've even read of people using SATA->PATA adapters with SSDs. That is still preferable over a mechanical if it is your only drive bay.
sweet deal but wtf amazon.ca?! that drive is $170CAN!?!?Plus, it is sold on Amazon.
