Arcygenical
- Jun 10, 2005
Arcygenical00 Fractal Iteration
Continuing my obsession with the Micro ATX form factor, I wanted to pick up a case that finally fulfilled all my cooling desires while being relatively compact and quiet. Though I loved my Lian Li A04, and really did enjoy the extra-small form factor, I found myself quite limited in the cooling department.
I was stuck with a single GPU loop and double radiator, and had no control over pump or fan speeds beyond basic BIOS settings. She wasn't a quiet case... Not to mention that the years were not kind to the setup's internals. Hardware swaps, and RMA's ruined my custom cabling, and I was forced to return to my stock corsair cables to accomodate my new Sapphire 290.
I want to emphasize that I am a modder, not a photographer. The only camera I have in my house, is an ipad mini, so until this case is completed, the glam shots will have to wait
Enter the Fractal Mini
First and foremost, I wanted to specify the starting colour scheme. Grey and Black
High gloss grey for the grills
Now we need to fill that pesky front hole...
And then mount our nice VFD fan controller by Akasa. 30w channels
Howabout another angle?
Time to mount the top 3.120mm radiator. The re-sweat of the closest barb is ALMOST invisible (the fitting got sheared off in my move)
Quick shot while the radiator was being flushed (you can see the glass of gross HCL to the left
Let's drill out the fan holes and screw in the 3mm LED holders.
Mount via buttonhead hex 6-32s and an allen key. Mock fitup with a dead Asus Gene IV
A view with some temporary fans installed.
One of the more important structural changes... Move the drive cage left 1"
Drilled some holes to soft mount the pump... Something I ended up not using since I was forced to make a change.
Let's paint and mount that swiftech 2.120!
Testing what a 9$ ebay 12v pump can do. Highly impressive TBH. Research for my next project, 500w of watercooled LEDs
