Honestly, I still have some too and it's definitely a go-to. Though I have wanted to try some others too just to see. I might try some Gelid Extreme.I still drag out the big tube of MX-4 when I paste CPUs. I'm not in a place where 1-3C is going to kill me either way anymore.
I still have a big tube of Arctic Silver Ceramique. it lasts forever.Honestly, I still have some too and it's definitely a go-to. Though I have wanted to try some others too just to see. I might try some Gelid Extreme.
Just built a new system about 2 weeks ago, used an IC Graphite pad. Couldn't be happier. Rated at 35W/m-k, which is more than triple what the high performance pastes are rated at. Arctic silver 4 is rated at 8.5W/m-k, the other Arctic Silvers were all less than 9 iirc. The liquid metals are rated 36 to 38W/m-k but are a huge pain in the ass, incompatible with copper or aluminum, conductive, and need reapplied annually (fuck that). The IC Graphite pads are also conductive, so it isn't surprising that the performance rivals the liquid metals. Compared to normal compounds, this pad has been very impressive.
i9-10900x air cooled with a Noctua nh-d15s (single fan), prime95, temp settles at 62C. Going to mount a second fan soon as I get the parts.
Probably some reviews someplace, you all owe it to yourselves to check it out.
30's idle, 62C all cores at 100%. These pads are really not that bad.
I don't buy the x-y-z axis... how likely are these pads "aligned" at the molecular level such that heat only moves in one axis? pfft.
Soon as I kill prime95, temp drops to 40 in only a couple seconds... heat is moving through the material very readily, and I am only air-cooling.
I'll get around to overclocking at some point.
It was some time ago that I tested it, but the old cpu/mobo, an i7-6850k, prime95 took that into the mid 80'c, maybe higher. On that cpu I used arctic silver "ceramique". Nearly as good, if not just as good as the "silver" arctic silver compounds.
I used kryonaut on my 3090, that was end of July 2021, so I will do a new GPU temp test soon.I haven't tried the Extreme version, but I did try regular Kryonaut a few years back and it didn't last very long before temps started shooting up again. Maybe 6+ months. It was also pretty expensive for how much you get. Definitely was not a long term use paste.
