Axman
- Jul 13, 2005
LTT video title next week:
With a 40-minute follow-up sermon from Tech Jesus that could be summed up with "It doesn't."
Top of the list was "Water based lubricant".
IgorsLab indeed warned against using any of these long-term, but said there can be a specific scenario where one makes sense. He tested the lubricant for up to a work day (8 hours) and it was fine. Mind that it is electrically conductive and take precautions. The gearbox oil has been tested for a few weeks. For a temporary benchmark build, or while you are waiting for your order of TIM to arrive, they will probably be ok.They didn't test long term.
Definitely would not use anything water-based in my PC that isn't contained. I'd be interested to see what the CPU looks like with the gearbox oil after weeks of use. I bet it's going to look and smell amazing.IgorsLab indeed warned against using any of these long-term, but said there can be a specific scenario where one makes sense. He tested the lubricant for up to a work day (8 hours) and it was fine. Mind that it is electrically conductive and take precautions. The gearbox oil has been tested for a few weeks. For a temporary benchmark build, or while you are waiting for your order of TIM to arrive, they will probably be ok.
Not sure about that. I've been using MX4 for a while, and I recently rebuilt my spare computer and it was brittle flakes. I think I pasted it 4 years ago. I thought it would last longer.MX3 and MX4 are both good. MX3 is very greasyy. The good thing is those thermal paste last very long. Means if you get off the heatspreader in 10 years from now, you will get still greasy paste not some solid stuff as with other thermal pastes, including arctic silver.
