So, I bought my first "new" Mac in October of 2006. It was a refurb Core Duo MacBook Pro. I had owned a couple of used Macs prior to this one. The computer was pretty decent, but it had a few problems right out of the box. I guess I'll list it out all according to date and then give you Apples solution.
10/2006 - The optical drive does not read burned discs. The top case is bent, does not fit correctly and a few screws are missing.
None of these things really bother me. I got a great deal on the computer and I work at an Apple authorized service center, so repairs were quick and easy.
12/2006 - The screen malfunctions. Basically it looked like there was a piece of dust or debris inside the display. Not dead pixels, just a strange shadow where the light wasn't getting through.
Again, the repair was quick and easy. I was only out the computer a couple of days.
3/2007 - The optical drive won't read burned discs and some brand new DVDs and CDs. I have it replaced again.
Well, that's starting to get annoying. I wonder if there is a problem with the optical drives Apple is using in the MBP. The first 2 drives were Matshita drives, while the 3rd one is an HL unit. The HL is a little noisier but it doesn't have issues reading anything.
6/2007 - My computer begins to shut down when the battery is between 10-20%. I suppose it might be normal, but the computer was only 8 months old at this time and I had the battery replaced under warranty. No problems at all.
12/2007 - I check my computer back into service for optical drive problems(again), and note that the display has a 2" wide vertical line that is dimmer than the rest of the screen. The service center notes the problems and opts to send it directly to Apple instead of replacing the parts in house. It comes back about a week later and the optical drive has been replaced, but the display was not. They sent it back to Apple again and a week later it comes back unprepared. I also noticed that whoever put it back together stripped out a few screws and the top case appeared bent, it wasn't sitting flush on the sides anymore.
Admittedly, I'm a little annoyed by now. Not at the service center, but Apple themselves. I called them up on 12/21 and explained the situation. After about 5 minutes I get transfered to one of the "specialists." She asks me what Apple could do to fix the situation, and I tell her that I just want a working computer. She asks if I would prefer a replacement or have mine repaired again. I just told her that I'd prefer whichever option was quicker.
Well, by the 24th I had a pre-paid shipping label. I got the computer shipped out to Apple on the 26th and on the 27th I recieved a brand new Santa Rosa Core2 Duo MacBook Pro.
All and all, I'm pretty happy with how Apple handled the situation. Now, FedEx on the other hand....
