Aorus 3080 Xtreme Rev 2.0 - DWM.exe Crash
Viper16
I lucked into the NewEgg Shuffle for a combo overpriced gpu and cpu...Aorus Master Rev 1 Z590 and Zorus Xtreme 3080 Rev 2..to the tune of $1500. I need a upgrade obviously. Well I hadn't purchased a cpu/ram/cooler yet, and installed this GPU on my existing setup. I am currently plagued with the blank screen, monitor disconnect, gpu fans 100%, and the disconnect/reconnect beep of the hardware. ctrl-shift-winkey-b doesnt appears to do anything. I DDU and rolled the latest drivers...still nothing. I have used one rail to power two 8-pins and a separate cable to power the third. The disconnect is random, and typically blips so fast I can't see what is happening. I notice stable 12.1, 12.2, 12.0 voltage on the 3-pins and even stable on the mobo voltage. I can run 3D MARK or play newer games with almost no fault running +2000mhz gpu, pulling +350 watts, and no issues. I go try to load satisfactory or outer worlds and it glitches by the time the first splash screen shows up. It is on a UPS with Sinewave output, I hear not clicking over to battery. I can run Iracing with Oculus, and wheel/pedals with no erroring out. It finally got bad enough that it locked my mbr up and I could not repair to get back into windows....which lead me to believe it may be failing ssd. I have experienced the blank screen and no boot before with the 1080ti in place. Sometimes I can go minutes, sometimes I can an hour or two before it happens.
I reformatted last night, loaded a game / latest nvidia driver on a fresh boot, and got the failure almost immidiately when going into the second splash screen.
I plan to invest in a CPU/RAM, since I already have the MOBO, but was hoping to be more successful with my GPU in its current setup. Is the old Z97 not up to the task? I feel the rails are providing full power and not hiccuping on the PSU.
TheSlySyl
Check what voltage the UPS is outputting (mine luckily has a display). I was having a similar issue recently and the cause was, weirdly, a combination of a nearby box fan in a window and an AC unit in a different room causing a lower AC voltage that was *just* enough to cause the same DWM.exe crashing.
Turns out that temperature wasn't the problem, it was the power draw. It wasn't low enough to kick the UPS on (only 105ish volts and it kicks in at 98V) but it was enough to cause something in the GPU to trigger the DWM.exe crash. It just so happened that power draw was lowered when the house was the hottest due to the Air Conditioning unit turning on and more box fans running.
Diagnosing it was an absolute pain in the ass. I did also downgrade my driver's back to 466.(something) and haven't tried updating again. I also set my GPU voltage back to completely normal instead of my usual 6% undervolt.
You can read my recent thread on it here:
https://hardforum.com/threads/1080ti-471-41-drivers-causing-dwm-exe-crashes-solved.2012548/
Viper16
Will give it a try. My UPS will show the voltage input, I will move it around so I can see the display and keep an eye on it. Everytime I have looked at it, it has had a strong 120-121 volts. Thanks!
Went ahead and ordered a my cpu/ram/nvme to finish up my upgrade path.
Viper16
OK, been playing around with this a bit. I finally upgraded the MOBO, RAM, NVMe and Fresh Windows 10 and Drivers. What I noticed, I can play older games with the power turned down below 50% and -150 hz in MSI Afterburner, I am talking hours and hours zero issues. I run 3dmark benchtesting with full power and have not had a crash. I can run it multiple times and zero issues. GPU is +2050mhz and 100% power, pulling +350 watts, no issues.
It is the GPU itself that is resetting, as it is the classic blank screen, gpu fans 100%, disconnect/reconnect windows sound, and wont reset display drivers until reboot, you can still hear the audio going on in the game. ctrl/win/shift/b just beeps.
I am using an older PSU, with one cable going to 2/3 8-pin plugs and a separate plug for the third power pin. I get a strong 12.1 volt on all plugs, and combined with the PCIE power I can pull +350 watts no problem. It could be a GPU power spike that could be causing a glitch in PSU failing the rail, causing the GPU to reboot, but would it not cause the PSU as a whole to shutdown? my APC UPS is the sinewave, shows a strong 122-123 volt supply. I checked wiring for proper plugging...I watch GPU-z and HWINFO and keep an eye on all temps/rails for proper voltage, and it seems good, but again could be a short enough glitch, trending cannot catch it.
If this is a strong sign of too much for my PSU, I have a new RM1000x at the house, but didnt really want to use it if It was not the problem....
anyone have any experiance in this issue?
kamikazi
Sounds like you've eliminated a lot of other variables. Why not give the new PSU a try? Weren't there actually some Seasonic units a couple of years ago that had a problem with newer video cards and they were tripping OCP really quickly or something? If Seasonic can screw up, I'm sure Thermaltake or whoever makes that PSU can as well. If you have to RMA the card, you will have at least done the troubleshooting.
TheSlySyl
What nvidia driver are you using? I haven't upgraded mine back up to 471 for fear of it crashing again, but I've been running fine on 466.27
What you have going on sounds exactly like what my issue was last week, but since i removed that box fan (and did everything else in that thread) i'm now at 9 days uptime with zero issues.
Viper16
kamikazi - I plan to install the new PSU, just didnt really want to spend another $200.00 if I could resolve it with my 750w PSU from my 2014 build, especially if it was going to do the same failing point.
TheSlySyl - I am running the latest 471.68 - my only other recent weird experience is when both of my monitors shut off, and then both go to sleep, only one will wake back up. I have to turn monitor off and then on again and it will boot up....very odd.
I will try my VR and make sure my wheel/pedals and all that are interfering. I had the GPU on the old 4790k system and it ran VR for over an hour and no issues.
pendragon1
Extremely [H]
if you have a new 1k psu, just hook it up outside the case to test. youll have your answer quickest that way...
edit: tried what thesylsyl said about power/ups?
TheSlySyl
Part of me also wonders if the DWM.exe crash is related to this somehow and multiple monitors (I have 3)
https://hardforum.com/threads/nvrla-exe-may-significantly-increase-cpu-usage-heat.2012758/
Try using DDU and reverting to an old GPU driver. I'm back on 466.27
Also, disconnect down to one monitor and see if it helps stability. It did help me at least to find a way to replicate the crash, which is how i troubleshooted the cause.
FWIW I'm also using an older 750Watt PSU (EVGA GQ) but I think you probably draw more power than mine does (Though my 1080ti does draw 280 watts on the regular.)
Viper16
I’d swap PSU’s no doubt. You’ve eliminated most other stuff.
Yeah I am thinking this is my issue...had thought it from the beginning but wanted to rule out other things. I tried to run Furmark with 50% GPU, the instant I hit 1080P stress the PSU would trip and reset power.
Dreamerbydesign
I would swap them. Sounds for sure like a PSU issue.
Viper16
Swapped PSU out, can get through Furmark on all tests...no issues. ran three separate 8-pin cables from PSU. Still have reset issue on the lighter graphical consumption games (satisfactory), GPU runs around 65%, I have limited FPS to 120, but there is something in the GPU MHZ spiking that causes the card to shut down. I left the power level @ 100%, but adjusted down -150 mhz on the Afterburner. I played for another couple hours and had no issue.
I think it has to do with the GPU ramping up and hitting the mhz ceiling, that causes the card to shutdown, usually around +2080 mhz.
learners permit
Vbios version? It appears to have a couple of updates with the latest being F71 if I'm looking at the correct GPU. The update change log states support for resizeable bar but no other notes.
Sounds like a defective card, RMA time.
Viper16
94.02.74.40.F5 ---so I assume F5 bios?
Viper16
Silly question: Are all the Gigabyte bios' stored within the AORUS Engine (downloaded within its software)? cause I cannot find any information about the bios versions on their awful website.
Don't think there are any for your card. Only Rev. 1.0 has bios updates listed.
kamikazi
That's a shame that the card seems to be a lemon. Hopefully, they can take care or you in a reasonable amount of time.
Viper16
All fine?
Doesn't seem to be, I moved to F6 bios with the switch on the card, assuming it is the "silent" bios, it lasted a tad longer on my game (satisfactory), but still did its GPU reset, game still on, audio still playing, GPU fans 100%. The only way I can play that game is with -150 mhz and 50% power on GPU. Of course I am still getting +100 FPS. I cant tell if it is a thermal shutdown or what...I am trying to figure out if I need to register the card on Gigabyte website first, which is partially shutdown due to their attacks, I will most likely start and email and ask them if there is anything in the works, thanks pendragon1 for the recommendation.
I had been exclusively a EVGA user for many generations, but it seems this issue is not uncommon with the other mfg's, just hope I made a good purchase. Afraid of my card being warrantied and getting lost.
Why do you think it will get lost?
Viper16
Lost in Freight or lost in the returns. Been reading some GB stories about sitting in GB receiving for a week or two before they claim receipt, and then another 6-8 weeks for repairs...unsure if backlog or just missing items. I would rather exhaust anything I could do on my end before physically sending it back.
I've done a few RMAs with gigabyte. Typically takes 2-3 weeks.
Viper16
Ok, finally Gigabyte had there registration services back up and running, got the GPU/MOBO registered. I ran some tests yesterday, played a few other games to see if I could get it to crash, I could not (Cities:Skyline, CyberPunk, Far Cry 5), while I did not hammer the games too long, I was unsuccesful. I did remember on my way to work this morning, that i set the Nvidia software to keep the GPU clock ramped up, so I will go back and turn that off, and play some other games.
Viper16
Figured I would update - I turned off the high performance clock setting in the NVIDIA 3D SETTINGS, have played Iracing 4-5 hours over the last two days and have not had one slip up. It appears my GPU resets are caused by certain games...and not all (Satisfactory, Witcher 3, Outer Worlds). I am running the GPU in F6 bios.
Running Furmark or 3DMark has not caused the card to crash, only when I had the older PSU in there, which fixed Furmark. For those select few games, perhaps I just lower the speed and power of the card when I want to play? I still get +100 FPS in those games at the reduced GPU settings.
Go into the 3d settings and set it to "prefer maximum performance" and see if the crashing continues. If it does I would RMA it. I would not accept a defective/partially working card.
Viper16
Well I sent the card back two weeks ago...had been checking there warranty status page...seems like they could not replicate any of the issues. Bummer. I get the card back on Thursday, so will see if anything was changed in the bios or the card is different.
So I guess I need to get to working on my computer and isolating the problems...never had GPU issues like this in the past, but have always had EVGA cards. Any tips on where to start?
If you need extended help I'd be glad to help you, have spares of everything. Just PM me.
