Aorus 2080 Ti - weak oc?
mgty23
Hello. My card Aorus 2080 Ti Rtx ( not xtreme,stock boost clock 1695mhz ).
I updated today bios to F3 from F2,but the same stability on overclock.
When i put boost clock to +80mhz it crashing in firestrike. On +70mhz ( 1765mhz boost clock ) its fine. Also voltage is maxed. Using Aorus Engine utlility. Memory is +700mhz. Maybe should i change program to Evga precistion or that doesnt matter?
Also power limit maxed,temp target maxed. Or just be happy with +70mhz?
Clock during load is something 2010mhz.
Somebody said that this overclock is weak and i should on 150+ on core.
stashix
Also power limit maxed,temp target maxed. Or just be happy with +70mhz?View attachment 146250 Clock during load is something 2010mhz.
Those cards are already pushed quite high from the factory, getting a sustained 2010 Mhz boost is IMO pretty good.
My XC Ultra runs at around 1930 Mhz for example.
mgty23
uhhh so left that ? And just test more to be sure stability? Yeah i know its not simple,one test tells nothing. Just more games to test actually yes?
TimeSpy Extreme stress test 78C even with fan speed 100%. Clock are 1920-1950mhz. Is this normal?
On games i have 50-65C.
zamardii12
Did you try Nvidia's OC Scanner? If so what results did you get from it?
