Anyone use PeerBlock?
Discussion in 'General Software' started by AMD_Gamer, Mar 24, 2010.
  1. AMD_Gamer
    AMD_Gamer [H]ard as it Gets
    18,290
    Jan 20, 2002
    Does anyone use PeerBlock? http://www.peerblock.com/ I was looking into Peerguardian 2 however it seems it is still very buggy, just wondering if anyone had any experience with PeerBlock?
  2. bigdogchris
    bigdogchris [H]ard as it Gets
    17,785
    Feb 19, 2008
    I would definitely recommend OpenDNS. Basically you just set your router's DNS server address to OpenDNS. Create an account and input your IP (it tells you what it is). If your on a dynamic IP, it gives you some software that runs on a computer on your network and it updates OpenDNS when your IP changes. From the OpenDNS account page you can create a custom filter that blocks a wide range of sites, Adware/Advertising sites happens to be on of the categories. Of course other sites like Pornography, Hate sites, etc., can be blocked as well. They also have generic low, medium, and high ratings that are predefined categories. You can also automatically white list or black list a website.
    Everything I described is part of OpenDNS's free package.
  3. Nighted
    Nighted Gawd
    632
    Apr 25, 2008
    I use it to block spiders and search engines from accessing my server. Works for me.
  4. Espeed
    Espeed [H]Lite
    79
    Aug 13, 2004
    I've been using it for a long time, when it was called Peer Guardian. Great Tool.
  5. zero2dash
    zero2dash [H]ardness Supreme
    6,092
    Oct 23, 2007
    PeerBlock is based off PeerGuardian, but up-to-date. http://www.peerblock.com/docs/faq#peerblock_vs_pg2
    Now they have a 64bit certified driver so you don't have to reboot and disable checking for this in Vista64 or 7x64, and they also fixed the blocklist server issue by making their own mirrors instead of using the Bluetack or the Sourceforge ones.
    PB has worked great for me, no different than PG really. Works better, actually. ;) (because the 64bit driver)
