I am trying to configure Iodine and having couple issues. Server is set up as
Client is set up as
When I connect, I get this....
I try to ping 10.0.0.54 with no success. Also, trying raw login fails. I did some research and can't find a solution. Any help would be appreciated.
iodined -c -f 10.0.0.54 -P password test.com
HTML:
Opened dns2
Setting IP of dns2 to 10.0.0.54
Setting MTU of dns2 to 1130
Opened UDP socket
Listening to dns for domain test.com
Client is set up as
iodine -f -I0 -m 1130 -P password test.com
Using DNS type NULL queries
Version ok, both using protocol v 0x00000502. You are user #0
Retrying login...
Retrying login...
Enabling interface 'Local Area Connection 2'
Setting IP of interface 'Local Area Connection 2' to 10.0.0.33 (can take a few s
econds)...
Server tunnel IP is 10.0.0.54
Testing raw UDP data to the server (skip with -r).
Server is at 10.0.1.19, trying raw login: ....failed
Retrying EDNS0 support test...
Using EDNS0 extension
Retrying upstream codec test...
Switching upstream to codec Base128
Server switched upstream to codec Base128
No alternative downstream codec available, using default (Raw)
Switching to lazy mode for low-latency
Server switched to lazy mode
Setting downstream fragment size to max 1130...
Connection setup complete, transmitting data.
