Anyone that uses Noctua with Phanteks Fan Frames?
orijin
Like the title says, does anyone use this combination, and if so do you have pictures to share of it? Are there any DBA sound levels increase because of the fan frames?
I was looking how the phanteks fan frames look on the noctua black fans.
Yep ive got some of both the 120 and 140mm frames. They just change the way the noctua ippc 2000rpm look. No difference in noise or airflow.
