I'm going to be installing an EK-FC580 (Acetal + Nickel) on my 580 and was wondering if it would hurt anything to us the 1mm pad on the vrms instead of the 0.5mm pad.
Would using the thicker pad impead heat transfer?
Reason I ask is the vrms look like they sit lower than the chokes, and according to the instructions the chokes have the 1mm pad and the vrms the 0.5mm pads.
Thanks
Thanks
