Anyone here know how to debrick WRT54G? If so, how much?
Discussion in 'Networking & Security' started by SNYP40A1, Dec 29, 2008.
  1. SNYP40A1
    SNYP40A1 Limp Gawd
    253
    Mar 13, 2005
    I bricked my Linksys WRT54G router this morning, a description of the incident is posted here:
    http://www.dd-wrt.com/phpBB2/viewtopic.php?t=44720
    Depending on the advice that I get, I might try the shorting 2 pins trick to see if that will allow me to tftp, but I don't think that will work in my case since I apparently used the wrong flash of DD-WRT. I will probably need to JTAG in order to debrick, but I lack the tools. Does anyone here enjoy debricking Linksys routers and if so, how much do you charge?
  2. supergper
    supergper Gawd
    766
    Apr 25, 2005
    Honestly, it's probably not worth it to pay someone. You can pick up a new wrt54g for ~$30, you'll pay almost that much in just shipping.
  3. YeOldeStonecat
    YeOldeStonecat [H]ardForum Junkie
    11,330
    Jul 19, 2004
    I've de-bricked using the pin short method on two routers. It's time consuming...not a fun experience.
    What was the version of DD you did? The full first instead of the micro first? If that's the case...it will usually come to life after several "resets" and power cycles.
  4. The Spyder
    The Spyder 2[H]4U
    2,629
    Jun 18, 2002
    I never got my V3 unbricked, what was worse is it just randomly bricked itself one day. Just stopped working, lights on just like its bricked. Anyone want it? I tried all the tricks minus a JTAG.
  5. omega-x
    omega-x 2[H]4U
    3,075
    Jun 21, 2003
    There's guides out there on unbricking via shorting the pins on one of the chips when you apply power to the socket
    except I'd actually call it fun ;)
