Anyone have an RX560 (14cu)?
Discussion in 'Video Cards' started by Private_Ops, Aug 12, 2018.
  1. Private_Ops
    Private_Ops [H]ard|Gawd
    1,824
    Jun 4, 2007
    Need a video card for my 880K but, due to PSU limits (Seasonic 360w gold) I need a video card without a pcie 6 pin.
    I already have a 1050ti in my main rig which would be a waste on an old 880K in my opinion. So i was lookin at the AMD side (kinda want to stay all AMD anyway).
    My best option is the 560 (14cu). Anyone have one? How does that model run with older Non-AAA titles?
  2. Dougie
    Dougie Limp Gawd
    189
    Jul 26, 2018
    That PSU should be able to power an RX 580 no problem. With that said, you should be able to run older games on the 560, but it's performance is below the regular 1050 in most titles, especially older ones.
  3. Private_Ops
    1,824
    Jun 4, 2007
    Oh it will (got an rx480 in the wifes rig) but soon as I put a load on it the PSUs fan goes into overdrive.
    Bet most would agree i'd be better off with a 1050ti even if it's bottlenecked some.
  4. mnewxcv
    mnewxcv [H]ardness Supreme
    6,260
    Mar 4, 2007
    1050ti is a great value. Or a 1050 isn't bad either depending what you play
