If so, what kind of temps/GPU power/core speed/fan speed you seeing in Furmark?
I have one and it seems to work fine, but I'm a little concerned maybe its cooling solution isn't doing its job as well as it should. When I run Furmark it pretty quickly hits 80 degrees C and then starts to throttle down settling on 75% GPU power, 1227MHz core speed, and 61% fan speed.
Case has reasonable cooling it in, it is a Corsair 540 with 2x 140mm fans in the front (also one on the back and one on the top), one of which is tied to a thermal sensor stuck on the card.
Is this expected and does it jive with your experience? It's not problematic per se, it isn't like the thing is shutting down, crashing or going real slow, it just seems the cooling solution isn't really doing its job. For something that supposedly handles 600 watts of dissipation running on a card that pulls less than 200 I would think it would do a bit more.
