So something along the lines of 'smart plant pi'?
https://www.switchdoc.com/smartplantpi/
Holy shit I wrote something like this for my grow tent
I never thought I'd talk about it ever again
Temperature and humidity can be read hiding dht-11 sensors if I'm not mistaken
You got light sensors too but you need an signal converter to read the raw value in lumens, or else youll get some binary reading (light on or off) which isn't super useful
The moisture sensors you find on Amazon are cheap as hell man, they stop being reliable after awhile
I didn't want to fuck around with bare relays and 110v so I bought this power bar that has outlets you can toggle on and off..it's called the IoT relay.
So you plug your submersible pump or whatever into that then trigger it by using crontab or something else more intelligent (the moisture sensors are not reliable enough to use as triggers IMO, not the cheap Amazon ones anyway)
Most of everything I wrote was in Python and some php
I was also logging to MySQL every couple mins
I'm not growing anything at the moment but soon I will put all this junk back into service
Sure man it'll be fun
At the time it wasn't one program, it was a set of scripts that I ran individually using crontab (Linux scheduler)
Ex monitor temperature and log
Then monitor moisture and log
Then monitor light and log
All every 5 minutes or so
Then I just put the watering on a fixed schedule that I would change once every so often because as the plants grew they needed more water naturally
So yeah absolutely you could water at certain times using a scheduler or any other program logic
Honestly the page the person linked above is really great. They've even got a 5v submersible pump that can be powered by the Pi! That's fantastic! They have a great write up there
Let me know if you guys run into issues, I can program as well, even microcontrollers like the microchip, avr (atmel), and I've done some arm development too (which all have built in ADC for reading sensors). I have a couple of rpis at the house as well. I mostly program in c and c++ with some c# and javascript when it's needed. (I probably have about 10+ unused microcontrollers of different flavors laying around).
Sounds good, I always enjoy a good one off. I helped someone on here with some custom 3D printed cable combs for his PC build recently. I just did the modelling and he got them printed locally (to him). I have a 3d printer but haven't used it for abs yet (and didn't have the color he wanted anyways).Excellent, I will be testing out some free garden watering app I found online and see how it works but I think I am going to want some changes to it so may just need a custom one written. I will surely hit you up if I end up needing to hire someone for this. Between you and blackmomba hopefully I can get something going. thanks all!
Did you have the model or link to the sensors you used? I'm curious what you got and how hard it would be to interface them.I tried getting it together last night but had the wrong sensors.. the app I was trying to test out uses grovepi shield and grove sensor.. I have the exact same sensors but not grove ones.. I guess grove ones are digital signal and the ones I have used analog signal or something.. anyway I ordered the grovepi shield and grove sensors.. once they get here (wednesday) I will try to test it again.
Come again?Are you work with react as well?
