Try disalbing the ULPS (Ultra Low Power State) for AMD cards.
Go to your registry (regedit) and change the following:
[HKEY_LOCAL_MACHINE\\SYSTEM\\ControlSet001\\Control \\Class\\{4D36E968-E325-11CE-BFC1-08002BE10318}]
and change "EnableUlps" to 0 under the 0000 and 0001 or 0003 keys or how ever many cards you are using.
***Always recommend backing up registry before modifying it***
thanks, I will give this a shot. Right now its working fine but its real picky when it wants to work. Ill do this and report back, thanks
Forgot to add, a you will also need to restart for it to take place. Always forget to add that.
