BrotherMichigan
- Apr 8, 2016
schmide can you give me an example of a motherboard that has been released two years before the release of the first DDR4 mobo that now support DDR4?
Socket != motherboard.
Seems like when the next memory standard hits on an actual motherboard the ram prices for it are way off the charts, I would wait a generation or two before moving to DDR 5 just not to waste money, plus when this occurs the speed difference from one generation to next initially just was not that significant, over time it was but not initially. So first DDR 5 memory - Super expensive and not much faster if history is repeated. Also memory issues abound with both Intel and AMD on their first go around with DDR 4 which basically took a year + to resolve for each.
epic fail
A good method.I use a processor affinity mask to load steam games on my even cores..
C:\WINDOWS\System32\cmd.exe /c start /affinity 555 F:\Games\Steam\Steam.exe -no-browser +open steam://open/minigameslist
The point is higher clocks for gaming because why not have the best chip for all uses or near as dammit if possible.People dont buy these to save power. All this discussion about power savings from folks that will never buy these chips. It better be ripping threads or else you wasted your hard earned. I owned two generations of Threadrippers. At idle they sip power. Gaming they dont use much. Fire up some workloads and they use some mad wattage but 90% of the time were talking sips.
I didnt mention power savings for another reason.
What cards are you looking at? If it's 5700XT doesn't it have pcie 4.0? That would make 4.0 x8 just as fast as pcie 3.0 x16I need more pcie lanes then 3950x will provide. Its a real shame their isn't something between am4 and tr4 on this front, I don't need 64 lanes, that is vast overkill, but i do want 2 16x video cards(plan to run vfio/project looking glass I need 2 16x cards not 2 8x cards) and 2 nvme drives.
What cards are you looking at? If it's 5700XT doesn't it have pcie 4.0? That would make 4.0 x8 just as fast as pcie 3.0 x16. That's a lot of bandwidth though. Do you know if they have nvme 4.0 x2 available? That would be just as fast as 3.0 x4 in theory. I need to read up more on current offerings, but my budget normally keeps me out of the bleeding edge category so I don't tend to stay as current since it's not normally my target.
Why don't he/she buy x399 its cheap as hell right now.[/QUOTE
Because it's a dead platform. We have heard nothing about backwards compitability, unless I missed something.
My bad what happened there.
Just a / missing or something.
It isn't dead as far as support. Just future chip releases, but I mean a 2950x is no slouch. It would easily meet that persons needs for years to come.
X399 is a dead end. Not only that, but while powerful, 2nd generation Threadrippers are kind of crappy at gaming. If you have a solid X399 board now and want to upgrade, I'd wait for deals on 2970WX and 2990WX CPU's. No doubt they'll be deeply discounted once the 3960X and 3970X hit shelves. Assuming they have any availability.
Dunno, if properly tweaked, they should just perform similar to a 2700X. My 1950X performs about the same as 1700X as long as I restrict games to running only on 8 of the cores to avoid performance penalties associated with NUMA.
Don't necessarily have to run in game mode to do that either, there are apps like process lasso to restrict which cores you are running on. So games can stay on one numa node, while you run everything else on the rest.
With TR3 you won't have to deal with NUMA which is a big plus but I think the older TR chips once they go on sale will be an amazing deal. At least for me 2700X performance in games is still very good.
Tr3 is gonna be just as fast at gaming as 3900x mark my words.
It very well could be; there aren't any real reasons now that the 3700X is rocking as well as it is, so the differences should just come down to RAM speed and core speed.
The biggest issues that Dan_D brings up above should also be addressed at this point, assuming that the dance between AMD and Microsoft has resulted in them coming to a complementary solution.
Third generation Threadrippers might be as fast as a 3900X at gaming, but that will depend on whether or not the scheduler behaves and localizes everything to a single chiplet.
It's also important to note, the 3950X may be faster than the 3900X. It will boost slightly higher and it has four cores per CCX and two CCX's per chiplet. That's 8c/16t per chiplet like the 3700X and 3800X. The 3900X on the other hand has 3 cores per CCX and two chiplets. This creates a scenario where crossing chiplets is more common than it would be for a 3950X.
Agreed; one would hope that the software side has been more or less figured.
I know that I've contemplated this before, and expect that the 3960X has a good chance to rise above the issues that have plagued the platform on and off with respect to more 'consumer' workloads.
I have no idea. Sadly, I haven't gotten samples from AMD at this point. Obviously, I'd be under NDA at the moment if I had been, but right now we don't have the CPU's in hand, so I can only speculate. I suspect we will see the 3960X and 3970X fall short of the 3900X and 3950X in some consumer workloads. Both the 3900X and 3950X have higher boost clocks than the 3960X and 3970X CPU's do. So that will factor in. Memory is also not likely to clock quite as well on TR40X as it does on X570, so there is that problem as well. Again, this is all speculative as I don't have my hands on any of the hardware yet.
Wish they released a 16 core part from Cascade that way we can determine IPC a little better. It looks like the 16 core Ryzen would beat a 16 core Cascade but it would be guessing without the actual part, but it does look like it possibly would.Sadly, I didn't have the new Threadripper parts for review, but that confirms what I suspected the result would be. Basically, looking at the specs we knew about ahead of time, Intel was going to get crushed. This is why Intel priced the Core i9 10980XE (stupid name) the way it did. It sits in between the Ryzen 3950X and the third generation Threadripper CPU's.
The 10980XE does not look faster in many applications over the 3950 and definitely slower in gaming. Well from the limited reviews I've seen. Yes some applications but overall it does not look that good. From performance perspective (depending on application) looks like the 10980XE sits below the 3950x.Sadly, I didn't have the new Threadripper parts for review, but that confirms what I suspected the result would be. Basically, looking at the specs we knew about ahead of time, Intel was going to get crushed. This is why Intel priced the Core i9 10980XE (stupid name) the way it did. It sits in between the Ryzen 3950X and the third generation Threadripper CPU's.
Impressive!
I was very surprised that gaming performance surpasses Intel I9 9900K in a number of games and overall is outstanding. Big change over previous Thread Rippers. In fact the gaming performance seems to be better than Ryzen 3 desktop versions (depending upon game as well). The performance is heaps above previous AMD TR chips and makes Intel 18 core look absolutely stupid in a number of ways. Now I want to build one but have to justify a use case for it.
Wow.... The gaming benches!!! With the cache benches it pretty much solidifies what I have been saying with regards to why the IPC is so much higher for Intel systems in gaming previously. It's the cache performance.
But somehow AMD increased the cache performance for threadripper specifically which would explain the delay. The fact that they took the time to do this is amazing.
The threadripper parts seem actually good for gaming this time around. So anyone that gets one will receive the boost in productivity apps and in gaming as opposed to it what it was the previous generation.
