dive_instr
- Nov 11, 2020
Hi,
There are torso only mannequin case mods out there.
Just brainstorming. Given that full body,
head to toe, mannequins are cheaper than they used to be,
it would seem to be a good idea to take advantage
of all the empty space. Head, and torso are one,
so components get more space than the torso only.
Adult mannequin should have enough space for
a modern gaming motherboard. Air circulation might
be fun to figure out.
Issue is clean cutting the fiberglass in the back, so
that the removed portion can be fitted back somehow.
Opening the head should be easy given that a wig will
be placed later. LEDs in the eye pupils might be neat.
