Anyone added an EVGA hybrid cooler to their 1080 Ti?
Discussion in 'nVidia Flavor' started by PTRMAN, Aug 7, 2018.
  1. PTRMAN
    PTRMAN Limp Gawd
    164
    Oct 28, 2008
    Looking at a used EVGA 1080 Ti FE with an EVGA water block hybrid cooler added on. Bit of a jury-rigged Ti Hybrid, with nearly 2 years warranty left on it.
    Appears to be these two items together:
    https://www.amazon.com/EVGA-GeForce...1-1-spell&keywords=EVGA+GeForce+GTX+1080+TiFE
    https://www.amazon.com/EVGA-400-HY-...226&sr=1-29&keywords=EVGA+GeForce+GTX+1080+Ti
    Anyone ever bolted on a cooler like this or used this kind of setup? Just wondering if it will perform as well as an factory-made hybrid...
    And the significant time lag between the original 1080 FE and other flavors makes me cringe a bit every time I see the words "founders edition"...
  2. doubletake
    doubletake Limp Gawd
    501
    Apr 27, 2013
    How exactly is it set up? Since the baseplate that comes with the FTW3 cooler isn't compatible with a Founder's PCB layout, I'm guessing they either modified the plate, or simply omitted it and only mounted the CLC cooler? Either way, it really doesn't matter; cooling performance will be excellent compared to the blower cooler. I did a similar thing myself using two 1080 coolers on my Titan Xs, removed the original vapor chamber heatsink and installed the CLC cooler with most of the stock cooler parts still on there.
    Armenius likes this.
  3. PTRMAN
    PTRMAN Limp Gawd
    164
    Oct 28, 2008
    Sorry - my bad. The only stand-alone 1080 Ti water-cooler I could find listed on Amazon was that one. I didn't look closely enough at description to catch the FTW designation.
    The original card IS a 1080 Ti FE, but I'm not exactly sure of the model number on the blower. All seller says is "EVGA GTX 1080 Ti Hybrid liquid cooler".
    EVGA confirmed that if both are their products (and they are), then they'll cover under warranty as long as a) original card is not B-stock and b) original cooler is put on. Seller says will include original cooler, so as long as card is not B-stock it looks good.
    Cooler reportedly has been on for a little over one year (probably done pretty much at purchase time) with no problems in performance. I just hadn't seen this before and wanted to get some opinions from the forum...
  4. ssnyder28
    ssnyder28 2[H]4U
    3,232
    May 9, 2012
    If its the standard hybrid cooler it is relatively easy to remove and replace. It should work way better at keeping the 1080ti cooler than the stock FE heatsink.
  5. IdiotInCharge
    IdiotInCharge Not the Idiot YOU are Looking for
    7,373
    Jun 13, 2003
    I'll say that the finished product is brilliant; if the integration was well done, I'd take it. I love mine.
  6. EvilViking
    EvilViking I Drank All Your Beer
    1,178
    Mar 7, 2005
    Love mine too. It's the only way I'll go now.
    I put an evga hybrid cooler on my FE 980ti. Working great. Huge drop in temps and noise. No offense to evga but I wanted to be in control of what tim was used and how meticulous the install was. So I purchased them separate to build my own.
    Plus at the time I heard of pumps failing or rattling (due to voltage mainly) I didn't want to have to ship my entire card if the pump did something. I could warranty them separate.
  7. Armenius
    Armenius [H]ardForum Junkie
    15,408
    Jan 28, 2014
    It's not "jury-rigged." The hybrid cooler from EVGA was made as a direct replacement and fits as well as an OEM cooler. I have one on my Titan X and you wouldn't be able to tell that it didn't come that way. It runs between 40C and 50C while gaming, overclocked to just under 2 GHz. A stark improvement to constantly having to deal with thermal throttling issues using the blower.
  8. kasakka
    kasakka Gawd
    888
    Aug 25, 2008
    Not an EVGA cooler, but I put a Corsair H55 on my 980 Ti with the Kraken G10 bracket. The primary issue with mounting an AIO water cooler is going to be cooling the VRM and memory. My MSI 980 Ti has separate heatsinks for those that stay put even if the stock cooler is removed so it was a good candidate for the mod. The card has run fine for a few years and is silent.
    IMO the cards that come with an AIO water cooler are often a bit half-assed, including the EVGA units. They still use the crappy blower fan and don't add a bigger heatsink for the VRM. At the prices it would be nice to have a proper waterblock that cools the whole card instead of just the GPU. They work fine but could be better.
  9. Nexus6
    Nexus6 Limp Gawd
    304
    Jul 29, 2004
    The EVGA unit includes a huge heatsink for the VRMs and a copper plate that connects the RAM to the GPU AIO block. It's not really halfassed in any way. The VRM fan doesn't even come on until 50c, is dead silent and easily keeps the VRMs under 70c.
    IdiotInCharge and Armenius like this.
  10. LigTasm
    LigTasm [H]ardness Supreme
    5,432
    Jul 29, 2011
    I had two 1080ti founders cards with the EVGA hybrids on them, worked great, looked fine.
  11. kasakka
    kasakka Gawd
    888
    Aug 25, 2008
    Seems they have a few different models now. The FTW is as you described and then they had another one that was essentially just the reference blower with the heatsink replaced with the AIO water cooler.
  12. IdiotInCharge
    7,373
    Jun 13, 2003
    I really have no idea what my MSI 1080Ti SeaHawk has underneath. I'll just say that it maintains 2,000MHz on the core and that it's silent. The H115i on the 8700k (280mm, single fan stack) is louder under load, and it ain't that loud.
    And I got that at $699 last fall, I believe.
  13. vjhawk
    vjhawk n00bie
    61
    Sep 2, 2016
    The built in AIO cooler on my GTX 1080 FTW Hybrid works a treat. Very quiet and keeps temps well under 60c for me during gaming. Assuming that the standalone unit is basically the same hardware I would say it's a winner. I also saw a video that showed by just upgrading the fan on that thing you could get it an additional 10c cooler. 50c max under load, wow!
  14. Astral Abyss
    Astral Abyss 2[H]4U
    2,649
    Jun 15, 2004
    Just wanted to 2nd this statement.
    The EVGA Hybrid cooler took my Titan X Pascal from a noisy, thermal throttled, toaster to a quiet, cool running beast. Runs mid 40 to 50C while being overclocked. I can maintain 2012MHz on the GPU indefinitely. Before, it used to bounce all over place as it would hit 90C and throttle down, fan then freaking out and running at full tilt 100%. This was while usually peaking at 1800MHz for a bit before dropping down to upper 1600s. I was shocked at the difference. I'm current (power) limited now vs thermally limited.
    IdiotInCharge likes this.
  15. PTRMAN
    PTRMAN Limp Gawd
    164
    Oct 28, 2008
    Thanks for the comments, all. I'm better educated now. Waiting to see newest cards will look like come Monday's Nvidia announcement.
    AthlonXP likes this.
