Any way to reinstall IE? I am having Temporary Internet files problems.
jamezzz122
The temporary interenet files will not save anymore. It won't allow me to set a value of how much disc space to use or mov eht folder. I don't think there even is a location because the current location is blank. I was on Myspace with a couple Windows open and all of them closed. When I view objects in the Temp Internet Files settings, There is 2 or three Macromedia items and two Java items. The two Java itens are show as damaged for their status. I think that might be the problem. Anyone with a similar experience and/or have advice. Thanks!
jamezzz122
Here are some more details I could get. It tells me to choose a vaule between 1 and 0 for the disc size when I try to choose any number. I can't mov ethe foler because it says tehre won't be anough spac einteh new location for the currently downloaded content. It says that when I choose a drive with over 200GB free. I don't know. It seems really messed up because pages seen to keep on loading without temp files.
