i've recently been reading up on DVI specs and how it's supposedly limited to 165Mhz. i noticed that people were able to force their dell 2005fpw monitors to run at 75hz in the native res, which isn't really far off from 1600x1200. however, when i go to adjust the refresh rate on my samsung 204b, i noticed that at 1600x1200 60hz i'm already at 163Mhz, with pretty much no headroom for a higher refresh. at 75hz the value goes up to 202Mhz and when i hit apply, it doesn't actually do anything.
i noticed that there are other values in the adjustment panel i'm referring to (using nvidia drivers 83.90 on a 7800gtx) such as front porch, back porch etc. these all affect the Mhz value, but i'm a little more wary about adjusting these.
basically i want to know if there's any way possible to get this baby to run at 1600x1200 75hz with the DVI connection. i am currently running it on analog at 75hz but the quality is notably worse.
thanks in advance!
thanks in advance!
