HiCZoK
- Sep 18, 2006
Hey everyone. I bought this in 2012 and it's still going strong.
I don't mind capping games to 30fps with riva tuner if needed but I feel like my pc might need some cheap refreshing anyway.
I will post list of my parts and what I think about them. This is what I have:
Motherboard:
Asrock p67 pro3 - so It's a super cheap mobo and it shows. I have fiio e10k and had to get pci usb extension card because the usb on the back were giving me pops in audio... besides that, its a solid mobo. No problem with oc or stability. Maybe I would just like it to be micro or itx... more on that later.
CPU:
2500k running at 4.5ghz with fixed vcore at 1.30. Stable and fast I think. no problems with it. Never going past 65 degrees C in gaming. And thats passive on macho 120. yes. I just remove the fan, no need for it as There are case fans above and behind it exhausting. I like quiet pc.
GPU:
Gigabyte 7870oc edition. I overclocked it even more. to 1170, so past 7950 levels. Its good. Don't think I have any problems with it. It stays below 60 degrees and thats with fans locked at 30%. its rather loud above that.
Memory:
2x4gb of Kingston 1.5v 1333 blu. I don't need more memory but maybe it's a good idea to get 2133 or 2400 ? It's rather affordable and some say they will speed up cpu, Not even sure if my mobo supports xmp and not sure what is compatibile with asrock p67pro3 and 2500k
Case:
Fractal 3000. Good sturdy case with lots of options. I removed front fan intaking air and just left back and up fan exhausting. No difference in temps. Just less dust and less noise. I like the idea of small form factor pc but I would need new case, psu and mobo... that supports 2500k.
PSU:
650W corsair gs. It's laud when gaming... and whiny all the time. IT does the job and looks good but I hate the noise. And it's not modular. I would like something modular and quiet.
Hard Drives and peripherals are all good. ssd 120gb plextor for system and old 1tb wd for storage. No problems. Got new monitor last month. 1080p. Don't need more.
So I wonder if there is any point in upgrading any part or just left it as it is and change the whole thing in like 2 years time.
So I wonder if I should just change ram and maybe psu or just go full m/iatx... but that can be a bit expensive. Would I gain any performance from going with better ram?
What about psu? Any budget silent modular options ?
edit:Btw. My firestrike score is a bit over 5900.
Motherboard:
CPU:
GPU:
Memory:
Case:
PSU:
