SilverSliver
- Feb 23, 2004
I have oily skin. I have an iCarez on my G3 and it gets smudged like crazy. Are there any really good oleophobic tempered glass protectors out there?
I just put a Spigen nano-thin on the G3, and with my hands, there is no smudging. I can still see prints under light from certain angles, but nowhere as much as on the phones, screen without it. You can almost clean what is left behind from use by giving it a stern look.
It's been my experience the oleophobic glass coatings wear off very quickly, even those applied by the cellphone makers at the factory. What we really need is a oleophobic coating solution you can apply every week or two, along the lines of RainX.
