hey sff guys, just saw this tonight when browsing newegg. never heard of giada, and certainly wouldnt buy from them til i at least learned a bit about the company, but i noticed that they put a mini pci-e slot on the bottom of the mobo which i thought was really cool. hopefully some other manufacturers see this and follow suit. it would be nice to have a slot for an SSD in addition to 4xHDDs, or maybe a wireless adapter.
That's not a Sandy Bridge board...
its been pointed out before & its not sandy bridge..
It's not underneath the board, but Zotac puts Mini PCIe slots on their boards too.
Anyone knows when the P67 Gigabyte mini itx board will be launched?
Looks like Gigabyte started to shipp fixed boards.
http://www.gigabyte.com/press-center/news-page.aspx?nid=991
So hope the ITX board with P67 is out soon
I can imagine Intel is madly cranking the chipsets out as fast as possible.
Msi got one at newegg. There's a couple of them available already
AsRock H67M-ITX now up on Newegg. Link is so fresh that they don't even have a picture up yet.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157238
Also available is the H67-ITX/HT with WiFi
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157239
wow, $40 more for a mini pci slot and a wifi card? pass.
The mini-pcie slot adds alot more to the board. They have TV tuners, wifi cards, USB3.0 cards, etc. for those slots. That was the only thing missing from the Gigabyte H55N I had before. I probably would have stuck with that board if it had one.
Many of the current mITX boards are able to use the Scythe Shuriken Rev B. (100mm) for cooling.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185097
In some of those setups (think the Gigabyte 1156 mITX board), the cooler comes right up next to the graphics card or even touches it. Most don't seem to have any issue with the Shuriken and the memory slots, so long as the memory doesn't have heat spreaders that stick up. That said, I think I would be tempted to use some of the Samsung very low profile (VLP) memory just to give extra breathing room between the cooler and the memory. The 4 GB VLP memory is here: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147066
I think we may just have to wait and see if some people are able to use the Shuriken Rev. B in these different boards. I imagine it will be relatively close on several of them.
Yeah, Shuriken will do the job. How about Big Shuriken ,NH-C14 and AXP-140? Will they fit?
If you want WiFi, thats actually a pretty good deal. Price a mini PCIe wifi card, antennas, and then fab an antenna bracket and $40 is less money and aggravation. Now, if you dont want WiFi, definitely save the money. And the standard one still has the mini PCIe slot, just unpopulated.
