Any recommendation for 27" ips high refresh 1440p
Discussion in 'Displays' started by Cylocybin, Jul 31, 2018.
  1. Cylocybin
    Cylocybin Limp Gawd
    282
    Jun 3, 2018
    Gonna look around throughout the day and figured i would seek forum suggestions as well,
    Thanks
    Budget : would like to spend less than 650
    Currently using a dell s2417dg 1440p 165hz and its been fantastic but im missing color vibrancy a little and getting the upgrade it bug
  2. Cylocybin
    Cylocybin Limp Gawd
    282
    Jun 3, 2018
    Not bad. Freesync tho :(
  3. Greg Watson
    Greg Watson [H]Lite
    98
    Jul 30, 2018
    Cylocybin likes this.
  4. Cylocybin
    Cylocybin Limp Gawd
    282
    Jun 3, 2018
    oooo yes that does look good, will be looking further into that one.
    thanks
  5. [21CW]killerofall
    [21CW]killerofall Aliens...
    2,701
    Mar 16, 2006
    https://www.newegg.com/Product/Product.aspx?Item=N82E16824106004
    I just got this monitor a week ago. Colors were excellent out of the box too, Delta E ~1.1 (<3 is considered good). I got it to less than 0.7 with a calibration. On sale right now. Some people complain about the OSD but it really isn't that hard to use and how often do you really need to use it anyway?
    isp and Cylocybin like this.
  6. Sycraft
    Sycraft [H]ardness Supreme
    4,273
    Nov 9, 2006
    https://www.viewsonic.com/us/xg2703-gs.html this was what I got for that purpose, and I love it. Can't remember what I paid but less than $700. 27" 144Hz (with 165Hz OC if you like) Gsync IPS. Decent settings for color and such in the OSD as well. Problem is they either aren't making enough or they are selling out fast because it looks like all the sellers right now are from Europe or are charging a stupid markup.
    Good monitor though, if you can find it for what it should cost.
    Lepardi and Cylocybin like this.
  7. Cylocybin
    Cylocybin Limp Gawd
    282
    Jun 3, 2018
    Awesome suggestions thanks
    getting harder to pick now lol
  8. Cylocybin
    Cylocybin Limp Gawd
    282
    Jun 3, 2018
    Still looking, cant find anything that screams BUY ME!
  9. Lepardi
    Lepardi [H]Lite
    117
    Nov 8, 2017
    XG2703 has been discontinued due to QC complaints of the AUO IPS panel, and is being replaced with XG2760 (TN-panel).
    I recommend to try the XG2703 while you still can, I got one with 0% backlight bleed on the first try! The gamma OSD setting is a saviour as well, with Asus and Acer are stuck with low gamma if you don't win the gamma lottery.
  10. Cylocybin
    Cylocybin Limp Gawd
    282
    Jun 3, 2018
    yea its only $1000 on newegg.. unavailable on Amazon
  11. Meeho
    Meeho 2[H]4U
    3,947
    Aug 16, 2010
    I don't know if there are newer ones, but they were all using the same crappy AUO panel with terrible QC issues. If there aren't new panels, I would avoid them all.
  12. Cylocybin
    Cylocybin Limp Gawd
    282
    Jun 3, 2018
    im just gonna stay put with what I have for a while..
  13. Lepardi
    Lepardi [H]Lite
    117
    Nov 8, 2017
    Gonna be a long wait then to be stuck with some old 60Hz panel, in about a year the similar LG 165Hz 1440p IPS panels will start showing up in stores.
    Just spin the AUO IPS lottery until you get a decent enough unit, then wait and see IF the new LG's will be any better... the good ones do exist, just need to be persistent. I'm quite enjoying mine now, 1440p IPS 144Hz glory with zero BLB.
  14. polonyc2
    polonyc2 [H]ardForum Junkie
    15,221
    Oct 25, 2004
    what were these complaints about the panel?...I bought that monitor this past March and have had no issues
  15. Meeho
    Meeho 2[H]4U
    3,947
    Aug 16, 2010
    Most have BLB issues and suffer from particularly pronounced IPS glow, more than the average IPS panel.
    polonyc2 likes this.
  16. Lepardi
    Lepardi [H]Lite
    117
    Nov 8, 2017
    I guess BLB, IPS glow and white uniformity issues. Mine shifts to cold in a small area at the right edge as well.
    But I just don't believe I can get any better unit since I have 0% bleed, so I'll definitely take a small bit of coldness that you can't see in normal use, rather than be stuck with 60Hz for another year.
  17. EvilViking
    EvilViking I Drank All Your Beer
    1,178
    Mar 7, 2005
    ThisĀ·
    Love mine. Got it for $500 new at Costco when they were clearing inventory.
  18. Sycraft
    4,273
    Nov 9, 2006
    Well that's a pity, because it really is a good monitor. Hopefully a new high speed IPS panel will come out soon so they can start making something like it again. High speed IPS is just so nice for games.
  19. Lepardi
    Lepardi [H]Lite
    117
    Nov 8, 2017
    We'll see how the quality turns out on those similar LG panels next year. There's also a rumour about updated AUO panel coming with the Acer VG270UP this year, but I doubt they will improve their QC, even though Viewsonic just dropped it for too low quality.
  20. isp
    isp 2[H]4U
    3,019
    Mar 15, 2002
    I'm satisfied with the XB271HU. Got it from the local Microcenter because returns are easy there. GL!
