Any problems going from Office 2000 to Office 97?
Discussion in 'General Software' started by Zick, Feb 18, 2005.
  1. Zick
    Zick Gawd
    532
    Jun 28, 2003
    I have a computer that currently is running Windows 2000 and has Office 2000 on it. For reason that do not matter, I have to put Office 97 back on the PC.
    I was planning on just uninstalling Office 2000 and then install Office 97. Well someone told me that is not a good idea because of certain files and DLLs between the two versions can cause problems.
    Need opinions on which course would work better and why?
    Thanks
    Zick
  2. JustLong
    JustLong Gawd
    751
    Jun 24, 2002
    http://support.microsoft.com/kb/q239938/
    SUMMARY
    A utility that helps you completely remove Microsoft Office 2000 is available from Microsoft. The Office 2000 CD1 File and Registry Eraser Utility removes most of the files and Windows registry settings that remain on the computer after you remove Office. This utility is designed to be used on stand-alone computers or workstations. Do not use this utility to completely clean a working copy of Office from a computer. Run this utility only after you run the Setup program for Office 2000, and then click Remove Office.
