I think most people would be looking for passive speakers and an amplifier in that price range... I'd suggest going to AVSForums if I were you. You're about to blow $1620.
Taking a huge chance buying speakers you've never personally auditioned. There's better options out there, especially for that price.
... All of that being said, I'm really curious... why are you so against passive speakers? Where was this conversation at? I mean there's just a certain size of speaker that you get to where having active rather than passive kind of becomes a pointless distinction, and it's not like all amps need to be big. If you get sensitive speakers for instance a tiny (literally thing is almost portable size?) Topping amp will drive them just fine.
Not really. There are lots of high end active monitors. $1500ish (for a pair) is getting in to the high end of most of them, but plenty of brands have stuff in that area. Mackie HR824mk2 ($1400), Presonus Sceptre S8 ($1500), JBL LSR4328P ($1550), Dynaudio BM5A MKII ($1400). It also goes a lot higher end than that. The Event Opal monitors are highly acclaimed and they are $3000. Genelec speakers start at around $1000 and go to $17,000 for some of their mains. And ATC? $8500 to get thier ATC SCM25A nearfields, and $20k or more for some of their large stuff.
All active speakers.
There's reasons to like active speakers. However I think the bigger question is why you are against them. Neutrino doesn't seem to be against passive speakers, he just found some active speakers he likes.
The thing to note is that passive is not the "right" way to do speakers. It is common, but that isn't because it is superior. That's not to say it is the wrong way either (though some people will argue that) but it is just a different way of doing things. Good speakers can be very good, regardless of if their crossover is active or passive, if their amps are internal or external.
<snip>
It's all in what you like and what works for you. There isn't a right answer.
Just a note though, AVSForum isn't so useful for active speaker advice. Since they are HT focused and that is a largely passive speaker market, that is what their members tend to have the most experience with. Gearslutz might be a more useful site, though they tend to have some elitist dbags there who are heavy on opinion but light on reasons for it.
Truer statement never uttered. Too bad it's difficult to actually know whether you'll like something without hearing it, and that these high end shops seem to be disappearing.
Whenever I upgrade them, I view any money sunk into the amplifier and active portion of them is utterly lost. Just from my viewpoint as a consumer, I see active speakers as getting "locked in... in a way". That is, for expensive high quality active monitors, I paid for both an expensive amplifier that is fine tuned to the speakers, and a pair of speakers. Had I went the passive route, I could make one investment into a good amplifier and DAC... and then never have spend money on that portion again. Anything that I spend on speakers goes PURELY into speakers. Active speakers on the other hand are buying both things every time you upgrade. To me that's just unattractive. For instance, I bought a cheap and extremely good Topping TP20 as my amplifier (and I use an O2 DAC+AMP as the source+preamp now... as well as the Source+Amp for my T1's) and as long as I keep getting sensitive speakers, I any speaker upgrade budget I have goes straight into speakers. I can then worry about the amp later if it's insufficient. To me that's a bit more freedom. So yeah short term I can see them being cheaper. Long term? I'm a bit iffy on that. Mathematically it seems to be a losing proposition to me.
Plus I just don't trust these companies. Unless I have blueprints and such, I have absolutely no way to tell just how much went into the speakers and how much went into the AMP portion, so I have no idea how much money I'll be losing when I upgrade. Oh, and forget surround unless I want to practically buy 2 AMPs+speakers every time I upgrade.
I don't really know but I think so. I'm pretty sure active crossovers are less destructive to the signal though. Passive crossovers cause the final impedance to vary. In practice with cheap speakers this is not an issue as much as other considerations, but if I'm spending big money on speakers I want active crossovers because it's not going to be any worse than a passive but is likely to be better. Ideally you want no crossovers at all.They're just filters, aren't they?
Basically, even if you sell it on Ebay, I look at it like this:
Cost of active (always) = (cost of) speaker + amplifier
Cost of passive (initial) = speaker+amplifier
Cost of passive (afterwards) = speaker
So suppose I have 1500$ for my upgrade, and I have an "overengineered amplifier". For active, that means 1500$ goes to both the speaker and the amplifier. I can't reuse the one I had from the previous set. That happens regardless of whether I sold my first one on Ebay. On the other hand, going passive I can reuse part of the components I initially invested in, and the money all goes to the speaker. That happens for all subsequent upgrades as well. Whereas with active speakers even supposing I sell them on Ebay the cost will have degraded some on the entire package. So I'll sell both the speaker portion and the amplifier portion back for less. On the other hand, my amplifier portion for passive will keep constant value for me because I can keep using it, and... oh hell it's been too long since I've done econ and that crap, screw it I'm not even gonna try.
Moving on, which option will sound better? Speaker+amp for 1500 or speaker for 1500 with my old overengineered amp (not the one I have obviously, this is a hypothetical scenario)? I cannot say, it's just a consideration to make. I'm satisfied with my setup... and either way I'm using my Beyerdynamic T1's for most of my listening right now anyway. But keep in mind that with passive, it's not just this 1500$ upgrade. Say your next one is 5000. Shrug. Same amp.
Surely there's some evidence on this or that site showing one way or the other. So some scientific measurements would be nice. That speaks better than theory. On the other hand I will note. You're assuming that active speaker designers always take full advantage of what they can. For what it's worth from all I can see regarding passive vs active crossovers, they seem to just be different type of circuits. Powered circuits vs nonpowered circuits. Which is what? The difference between having an OP amp and just doing a regular RLC filter? At that point it's just about the measurement of the output. I'm sure well designed active and passive circuits do fine. They're just filters, aren't they?
Simulation is simulation. Your simulation software doesn't account for the drivers parameters etc. that complicate the design in real life - or the impact to the amplifier load.
Active is superior to passive. This is how it just is.
Unless you have actual data to back it up, stop making these blanket statements. You keep saying that there are all of these complications for passive filters, but active filters have their own complications.
Moreover, my MS Aviano 2's, as well as most high end speakers... iirc let you just utterly bypass the crossover and feed whatever you want into both the woofer and tweeter... at least that's why I think it has 4 knobs...
I don't think it is necessarily that passive filters are more complex, as in have more components or the like, it is that they need higher quality components and are more fiddly and expensive to design right. Good passive crossovers are usually pretty simple for a circuit layout standpoint. However the components they use are often pretty pricey. As expensive as a good opamp is, they just don't compare to the cost of the high end caps you'll see in a nice passive crossover.
That said, I think the hype on active speakers is a bit overblown, at least in practice. Like in my little test of the SVS speakers vs the Presonus speakers. Personally from my experience I find the "active vs passive" question to be more one of what is the most useful in your given setup, not one of absolute superior sound quality.
Hence why I say overblown. Not because it is a bad idea, but because it doesn't seem to be this thing that is just some massive step up. If it was, I should be able to grab pretty much any competent $1500ish/pair set of active monitors and say "wow, that is a lot better than what I have." However, I find that's not the case. If I stepped up to something like the Event Opals, ya probably be better. But then I could get better passive for that price as well.
You only need 1 amp for the passive system. That's nice and simple.
For the active crossover system, you need an amp AND a DAC for each output band. That's not as simple at all. It is *probably* going to sound better, though. But not if the manufacturer ended up having to cut corners on the materials and electronics to get it all done.
See that part where the Active crossover network gets split out to 2 amplifiers? The active crossover network is digital and the amplifiers aren't. So you need a DAC to feed each amp. Guess how many DACs a 3-way active crossover network has in it!After the pre-amp the active crossover filters it for each amp like so:
It's been known for a long time that active is superior to passive.
http://audioundone.com/8-advantages-of-active-crossovers-douglas-self
Active's "complications" are only it's more expensive initial cost with having to buy more equipment and having the knowledge to set it up correctly. It's advantages outweigh it's downsides. Passive's advantage is an initial reduced cost in having less equipment to buy upfront and end user convenience as the only setup knowledge they need (but is often ignored) is correct placement.
That's not active, that's passive bi-amping which has no benefit. You'd have to open up your speakers and disconnect the passive crossover to make it active.
http://www.chuckhawks.com/bi-wire_bi-amp.htm
From your previous posts you go into being "locked in" in regards to active setups, this is only in the case of active studio monitors with built in amps. With designs that aren't active studio monitors one would generally buy the amps once and only replace an amp if one needed more power or the amp died.
Passive filters are much more complex. There's a lot of design, testing, measuring and redesigning repeat... It's time consuming and expensive especially if you're not already proficient in designing passive crossovers. With active you can test and measure the differences in real time until you reach the set it and forget it point. Also the benefit when testing and measuring with active (obviously not with active studio monitors or others with built in amps and active crossovers that aren't user definable) is you're more than likely in the room that you intend to listen to the speakers in whereas with passive they were designed in the manufacturers testing chamber. Sometimes people forget or don't know that the room is just as important as the speakers themselves.
Active isn't overblown, it's the next step towards uncompromised sound quality if that's your goal. If you want a state of the art speaker system, active is the only way to go.
Once my warranty is up on my ML's I plan to convert my L & R ones to active. I think I have 2 years to go. I would've done it already but I don't feel like footing the cost for replacement panels if they happen to fail in what would've been during my warranty coverage.
No one said D/A conversion was lossy. I said it's complex, from a certain perspective, to use active crossovers--particularly when you are trying to make a cheap integrated system, when all of these separate amplifiers and redundant DACs start to eat away at the budget, leaving very little for the speaker cone material and amplifier components.
As to what you're discussing here, this is getting into the DIY realm where you're talking about an active crossover circuit that you set up once and then modify for subsequent speaker purchases. That isn't really what I'm going after.
But no seriously, does someone have some lab tests that show THD, gain, etc. for active vs passive crossovers at given price points? That's all I'm really trying to get out of you folks. I don't mind admitting that active is superior (I would hope it is, you need an extra +/-15v source for powering all of those op amps),
I just wanna see some actual data. I'm an engineer, I don't believe things unless I see the tests.
The problem is you're comparing apples to oranges. You can find examples of X-brand and model passive speakers that are better than X brand and model active speakers and vice versa until the cows come home. To be able to reliably hear the difference between active and passive you need to have the same speaker drivers in the same cabinet in the same position in the same room etc and then compare the passive vs the active versions. As long as they're both setup properly the active version will always be better. It's kinda like lifting a veil. Once you experience that you'll see it's a massive step up.
I don't rule just rule out passive because it's passive. If I was comparing different brands of active and passive speakers I'd pick the one that does sound better regardless of the crossover. However if it was a passive design you can best bet I'm thinking of converting it to active at some point in the future.
Behringer B2030A vs. B2030P?I am not aware of a company that says "Here is Speaker A and B, they are the same except for being active and passive."
While I am highly biased here, I believe Dunlavy holds a strong claim for being the best crossover designer ever. Stereophile published an interview with him way back in 1996, & Dunlavy's comments on active systems & DSP are worth a look. A true shame the Magnus never made it out of the prototype stage...The studio on campus uses Dunlavy SC-IVs as their control room monitors and man, what a great sound. Now that is a set of like $6000 speakers hooked to an amp that is probably another $1000, but compared to the also pricey active units (can't remember what) in the studio itself they were clearly better.
Yeah you're not reading carefully. The DACs are IN the crossover. ALL digital crossovers require a DAC... The point is its pricey.Why do you keep implying that active crossovers need the end user to also buy separate DACs before outputting to the amps?
