Any one looked at Chia yet?
lobstar
this, I'm at 35 plots and hitting a ceiling on plot time v. Estimated time to win. I have some spare hardware sitting around and just using regular HDD's to plot, which isn't that much slower than my M2 drive, M2 Drive plotted 14 over the weekend regular HDD did 9.
I'll fill the 8TB of space I have for it and call it a day, either something happens or doesn't. Not putting actual cash into this.
The way network space is growing is insane. The number I saw yesterday was 72% increase per day. There is no way a normal person can keep up with this.
kirbyrj
I'm thinking of just setting it up in a docker on my Synology and treating it more like a lottery. It shouldn't cost me much to run it.
Aireoth
I use my synology for it, that and a 2TB drive in my PC that I don't use.
Used to use it as a plex but haven't for 5 years now, might as well repurpose it into something.
DPI
For solo mining, you're chasing a departed train you'll never catch. The better play is either selling plots or selling your harddisks while price is inflated. I bought a bunch of 14TB drives for $160 right before the Chia crunch happened, intending to migrate and swap out all my 10TB drives, so now I'll prob just sell one or the other set of drives since the resale delta will far exceed any mining reward.
In general there are just too many things wrong with Chia to devote serious resources and expense to, IMO. Where it's based, who's behind it, the absurd pre-mine, the list goes on.
kirbyrj
Once pools come out join one and let it trickle in.
I guess you can pool mine with hpool. Essentially you just plot for them. I don't know if I trust some website that I have to keep changing to English from Chinese.
lobstar
Hpool is a scam. Don't farm on someone else's keys and don't give your keys to someone else. Numerous people have been banned for no reason with no recourse. Stay far away.
Noetic
I purchased a pair of 12 TBs and an 18TB just as the crush was starting. In fact two sellers reneged as the prices jumped.
Problem I have is I cannot plot fast enough. I am using windows 10 and a 9900k with 48gb ram, and I crash plots almost 40% of the time.
I started before chia hit 2EB. Now it's over 6.5EB. Is it going to worth chewing up my 4tb nvme?
kirbyrj
I'm starting to think that it isn't worth it. Even with 60TB after you're plotted, you're going to fall behind in raw space. You're essentially buying a $2000 lottery ticket with the drives to win $2000 of XCH.
I have 4TB plotted and that's all I'm doing. I'll let it run in the background and maybe get lucky, but I'm not thrashing my SSD for essentially no chance at winning anything.
Noetic
I bought an old HP z640 workstation with a 14 core Xeon CPU to run the plotting in Linux (hoping that I can move the disks over without losing the plots and thinking that at least I can use it to replace my office server in the future.)
Yeah... I got into this too late.
kirbyrj
Is it just me or is the software buggy with syncing? I had a power failure on the computer that runs the chia client after tripping a breaker. Now I have to restart the program multiple times before it will start to sync.
lobstar
Lots of people report that but I've never had an issue. 1.1.6 should fix that and is available now.
kirbyrj
How do you update? Just download the newer version and install over the old one or is there a way through the client?
Noetic
Ok... stupid question here. Can hybrid drive be used in place of ssds for temp drives? Speed vs cost benefit.
kirbyrj
It shouldn't make a difference for farming. For plotting, I would think it would be slower. The hybrid model is built on putting recently used data on the SSD portion for faster retrieval. I don't think plotting would benefit from that model.
lilfiend
You'd see a MUCH bigger difference running linux instead of using an sshd. linux will automatically do write-back and read caching with your excess ram which will perform much better then whatever limited amount of flash they put on the hard drive.
Noetic
I saw this as a less expensive replacement for ssds
Chia is a bit of a pain to set up on linux, and I already have it started on windows with two machines.... Oddly I entered the same account on the separate machine but they do not see eachothers farms
draksia
it is my understanding that you want to run only one node per external IP address and have that node talk to the individual harvesters.
That said I did finally get a block yesterday morning with 348 plots so far.
Noetic
Congrats on the the block.
From what I see on Reddit, I came in a little too late and a lot to slow.
I started at the beginning of the month and have had too many lock ups trying to maximize my farm. Simple to say, May 1st, chia is seeing its first EiB. Now, it is screaming toward 11EiB. Even if I have my 50 TB up and running, I would be lucky if I ever saw a Chia.
Pigheadedness is keeping me in when I should fold.
Noetic
Trying to see if I can move my drive plots from my window box to a linux....
Cypher-
Chia really wasn't an issue to get setup on linux IMO. I'm running it through SSH so no GUI. Just follow their command line guide and use '-h' for everything. Everything is documented with '-h' so it's pretty easy to figure it out.
For what it's worth, I was keeping my estimated time to win consistent with ~30 plots per day so I imagine if you want to actually see the time go down you'd need to be doing more than that. I've plotted ~72TB and could do another 10TB or so if I wanted to max out my NAS but at this point I'm going to keep it as swing space for when pooling comes out. I think I'm going to do K33s for pools. When I first started there was a mad rush to get as many plots out as quickly as possible. With how fast Chia grew I feel like that rush is over and now it's just going to be the long game so I don't care if the K33s take longer, I'll still be farming my solo plots with the new pool plots at the same time and slowly replacing them.
This has been a fun experiment for me regardless. My NAS is actually running 40Gb Ethernet and at one point I had two of my servers transferring at the same time and I saw almost 2GB/s writes. That's the first time I've ever seen the 40Gb come in handy lol.
Noetic
I got it set up in linux , entered the 24 word code, but is asking for backup.... moving drives over is going to be a pain.
Must say, I am impressed with the way some of you guys are getting plots going.
To be honest I am about 5 years out of touch with pc building.
legcramp
Is it worth moving your plots if you only have 50tb with the ever increasing net space?
Just fill her up and farm imo. Prep another system with Linux and get ready to replot for pooling.
Noetic
It has been 3 weeks and thanks to crashes from my optimizing attempts, I only have 12TB farmed. Hence my thought of trying linux, which fought me on drive permissions. Not a Linux expert. Feels like the cli on the Amiga, but I do not know the codes
meh... I'll keep plugging away.
