I'm currently a PHP developer and looking to learn .net for building software, not web apps...I've toyed around with VB6, but it's been a longgg while...before I begin I just have a few Q's
-seems like WPF is the new way to go for developing software front ends...are there any drawbacks to using it? or 100% FTW?
-is vb.net these days as powerful as c# or does one still hold power over the other?
-what's the most common database used when developing .net apps? with PHP it's all MySQL, so just curious if there's an equivalent.
-is MySQL well supported with .net? anything I should be weary before deciding to use it? limitations?
-is there a good resource for finding .net code around? seems ot be a LOT harder to find resources then PHP ever was? I am guessing cause it's not open source.
-any books y'all can recommend? I just need to know the structure of doing things with .net...I have about 4 years exp with php, so I got it locked down
