Any interest in PicoPSU based Mini-ITX case?
Discussion in 'Small Form Factor Systems' started by loneindustries, Feb 8, 2013.
  1. Cov
    Cov Gawd
    917
    Dec 3, 2007
    Hi, this project is awesome. Always wanted something clean & neat like this.
  2. saprahan
    saprahan n00b
    9
    Jan 29, 2014
    deleted
  3. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    Thank you!
  4. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    Here's a quick photo of the L1 (2013) with an acrylic side panel. I have a few of these acrylic side panels if any existing L1 owners would like one. The holes aren't countersunk.
    Also, not available quite yet, but here's the slightly revised L1:
    [​IMG]
    [​IMG]
  5. ellroy80
    ellroy80 Gawd
    643
    Apr 2, 2005
    Can the revised fit a dual slot low profile video card?
  6. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    No, this is essentially the same as the original L1, with a few tweaks.
  7. Stevo_
    Stevo_ Limp Gawd
    285
    Dec 27, 2012
    What's the availability look like on the new ones and colors?
  8. ellroy80
    ellroy80 Gawd
    643
    Apr 2, 2005
    IMO, you are shooting your self in the foot, so to speak, by not supporting dual slot video cards. There are few decent single slot video cards available these days.
  9. Drown Babies
    Drown Babies Gawd
    658
    May 29, 2005
    I would like to see a two-slot version too, but for now there isn't much to take advantage of it. The 7750 is still about as good as you can get in low-profile. I guess there are some two-slot 650s, but those are in the same range as the 7750.
    Hopefully the 750 will change that, but we'll have to wait and see.
  10. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    Hopefully end of this month, beginning of March at the latest. The colour is a new very smooth flat black. I didn't do white this batch.
  11. ellroy80
    ellroy80 Gawd
    643
    Apr 2, 2005
    Yeah but you are still stuck to manufacturers' heatsinks etc. It would be nice to have the option to passively cool, or add a larger fan below the video card, or..... The point is, you increase your market by giving people options. Just MHO. FWIW, I have an L1 from loneindustries and think it is a really nice case. I'd just really like to see a dual slot version.
  12. Alted4
    Alted4 n00b
    55
    Nov 20, 2011
    XFX makes a low profile dual slot R7 250. Couple that with an A10-7850K and you have a pretty powerful system for its size.
  13. Alted4
    Alted4 n00b
    55
    Nov 20, 2011
    I think it would be helpful to notate the new version of the L1 as the L1 (2014). Having L1 and L1 (2013) makes it sound like the 2013 version is newer.
  14. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    I agree. I'm sorry the 2014 L1 wasn't what you were hoping for. I've been so busy with my full-time job, that this is all I could pull off at this point. Just so you're aware, if I do come out with something else that fits an oversize heatsink, it will have a different name. :)
  15. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    Thanks for the suggestion. I didn't add 2014 to the name, but did make it more clear that the L1 2013 is clearance priced. I only have one L1 2013 left, so I hope it's not on my site for too long.
  16. sgtspiff
    sgtspiff Limp Gawd
    137
    Jan 14, 2011
    I will also join the choir chanting for double slots.
    I've found a few odd and ugly double slot itx cases but nothing worth buying.
    As mentioned an A10-7850k dual graphics with a R7 250 (or even 250X) would require double slots.
    I would also like to see a 140mm fan on top of the mobo.
    The existing cases are really nice though you should keep the style.
  17. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
  18. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    There's no ETA. When I have more free time, I'll put more work into what I've already started.
  19. updawg
    updawg Gawd
    608
    Mar 20, 2010
    If you made this case I would be so happy!
    You should also consider being able to accommodate this new psu inside the case: http://www.hd-plex.com/forum/showthread.php?t=871
    250 Watts with a six pin pcie!
  20. ellroy80
    ellroy80 Gawd
    643
    Apr 2, 2005
  21. Drown Babies
    Drown Babies Gawd
    658
    May 29, 2005
    It looks like that might fit in already. It would probably prevent you from installing a drive with the standard bracket, but with so much space in the front you might be able to find another way to squeeze at least one drive in.
  22. Saint001
    Saint001 Limp Gawd
    204
    Oct 14, 2011
    Lone had something drawn up awhile ago for the X51, this looks to be a similar profile if he wanted to move forward with a bracket. You'd have to get creative with the drives but that's not a huge issue.
  23. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    Might be more do-able in a larger version of the L1. If I simply enlarge (scale up) the L1 to add dual slots then the dimensions would be 240x101x240 mm (LxWxH). Or I could leave the length at 220 mm which would give 220x101x240 mm.
    Without the room at the front, you could attach at least one 2.5" drive onto the side panel, over the motherboard.
  24. Alted4
    Alted4 n00b
    55
    Nov 20, 2011
    With an mSATA SSD and self adhesive stand-offs like these it should fit easily on the front panel.
  25. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    @Alted4 - That'd be perfect.
    @Everyone - Those who are serious about wanting to buy a dual slot version of the L1, please post so I can get a count. As mentioned, it would be slightly larger than the L1. Also, post whether you'd be willing to pay $150-160 for one? It wouldn't take me long to produce a slightly scaled up L1 with dual slots.
    (I'm maintaining a list offline)
  26. Saint001
    Saint001 Limp Gawd
    204
    Oct 14, 2011
    I'd be in for a black one. Day one purchase.
    If you can do $150 or less it'd be great, but I understand your costs regardless.
  27. TimeHacked
    TimeHacked n00b
    12
    Dec 23, 2013
    I may be interested in one, but it really depends what I can find for a GPU that will fit in 2 slots and in the 101mm width dimension. I'm not an avid gamer but I wouldn't mind a decent GPU.
  28. Alted4
    Alted4 n00b
    55
    Nov 20, 2011
    Would this larger version have full or half height PCIe slots? If full, put me down for one.
  29. ellroy80
    ellroy80 Gawd
    643
    Apr 2, 2005
    Don't add me to the list at the moment. I'm definitely interested but will be moving later in the year so am currently looking to get rid of stuff instead of adding it.
  30. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    This would be for half height cards still.
  31. updawg
    updawg Gawd
    608
    Mar 20, 2010
  32. Shockwave818
    Shockwave818 [H]Lite
    73
    Sep 23, 2013
    What dual slot half height video cards are available now?
  33. Drown Babies
    Drown Babies Gawd
    658
    May 29, 2005
    I'm definitely in for one at that price. I really like the white, but I'd take black too.
  34. ellroy80
    ellroy80 Gawd
    643
    Apr 2, 2005
  35. ellroy80
    ellroy80 Gawd
    643
    Apr 2, 2005
  36. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
  37. sgtspiff
    sgtspiff Limp Gawd
    137
    Jan 14, 2011
    I'm in as long as you can ship one to sweden.
    Dual slot in my mind is only so I can get a passivly cooled card.
  38. ellroy80
    ellroy80 Gawd
    643
    Apr 2, 2005
    Depends on what size cooler the manufacturers use ;). I'd rather use a large passive cooler than a single slot with a small, loud fan.
  39. loneindustries
    loneindustries Gawd
    538
    Feb 6, 2013
    I have shipped to Sweden once.
  40. s0skey
    s0skey n00b
    47
    Sep 27, 2013
    Put me down as a maybe. I already have the single slot version and love it. My computer case buying is becoming a problem haha.
