I have gone through several flex ATX PSUs and they were all absolutely awful. Even with a resistor on the wire. Only one that wasn't bad was the one that I made another case for with aftermarket fans on it.Tiny fan on these flex ATX PSU's = noise
Any thoughts on me using hex/allen drive type instead of phillips for fasteners?
For the M3 flat head fasteners I'm using, Hex/Allen is more common in black, whereas Phillips is less common in black. On the other hand, everyone is likely used to phillips fasteners with computer cases. Not sure if it matters much, or if people will revolt at the site of a hex/allen fastener?
Allen are cool looking imo, and less likely to strip. So long as you get the round head version and not the ones that stick out like like little castles
Thanks. They'll actually flat head screws, due to the countersunk holes. Someone could flip the side panels around and use button head style if they wanted though.
Even better. Are you going ahead with these cases? If so what iterations have you decided on?
Looking nice, my guess is the size difference wouldn't be easily noticeable unless it's sitting right next to the L1.
Yesssssssssss
I was worried it would be a lot bigger but this is still a nice size. cant wait to see more!
I agree, you're probably right.
You and me both. I'm still a little worried to be honest.
How many people want something to use in a horizontal position?
What will the actual dimensions be like for the L2?
I use my L1 horizontally and would do the same with the L2.
Horizontally absolutely.
Hanging under my desk as my current system.
I'm tempted to design something specific for use horizontally...
I didn't know this was designed for vertical use. I plan on using this as a htpc and a vertical orientation would not fit in my entertainment unit.
Do you mind how the L1 is designed to be vertical, with the flanges on the bottom?
Are those screws already part of L1 2014?
Subtle, but I like the look of the hex screws better. Sort of like the wood background shots better on your webpage as it gives a look like it's on desk, but I'd take shots that show all 4 sides at a minimum no matter what the background.
BTW, ordered my L1 the other night when they first appeared, got everything ready to go and can't wait!
Thought I should make it known that the Galaxy 750 ti LP just released. Just ordered one myself in wait of the prospective L2.
Galaxy Link
Its looks like a sweet little card. Hopefully Zotac and others will follow suit.
Unfortunately Galaxy isn't in North America anymore.
Send some to the states
That is just for a retail presence. I bought one through their web store with no issues at all.
Galaxy Link
