Any Ideas On Things To Implement In Pfsense?
Discussion in 'Networking & Security' started by S-F, May 12, 2018.
  1. S-F
    S-F Gawd
    646
    Aug 5, 2010
    I just last week made the switch from DD-WRT to pfsense and now that I finally have everything running the way it was on my old router I'm looking for ways to leverage all of the possibilities of my new machine.
    Ad blocking:
    I used to block ads using this pixelserv method and it worked rather well: https://www.howtogeek.com/51477/how-to-remove-advertisements-with-pixelserv-on-dd-wrt/
    I have followed this guide for ad blocking in pfsense: https://www.linuxincluded.com/block-ads-malvertising-on-pfsense-using-pfblockerng-dnsbl/
    Does anyone have any thoughts they'd like to share about the guide or any other ideas they'd like to share?
    VPN:
    I have been using PIA as a VPN service for over a year now by running the client on individual machines. Yesterday I got it running on the pfsense router and it's great. Does anyone have any ideas on ways to possibly improve this?
    I guess at this point now that I have everything up and running I'm just looking for ways to take greater advantage of my possibilities. I see that there are a ton of packages but I don't really have an in depth idea of what they do. I looked into using squid to cache web traffic but it looks like it's all but impossible for https.
    Any ideas or tips are highly appreciated!
  2. wolfofone
    wolfofone Gawd
    698
    Aug 15, 2010
    Hmm https cache should be possible though you may have to install certs to each PC. Not sure...
  3. WhoBeDaPlaya
    WhoBeDaPlaya 2[H]4U
    2,575
    Dec 16, 2002
    Too lazy to setup adblocking myself.
    RPi + PiHole = done deal for all devices on the network.
  4. S-F
    S-F Gawd
    646
    Aug 5, 2010
    I think I set up all the pi-hole stuff in pfSense through PFBlockerNG using the DNSBL feeds the pi-hole uses. I think............... From the guide in the second link I posted. Has anyone done https caching?
  5. rtangwai
    rtangwai [H]ard|Gawd
    1,344
    Jul 26, 2007
    If you need remote access to your network you might want to implement OpenVPN.
    Squid and SquidGuard are useful too if you have a lot of devices connecting to your network.
    Maybe a RADIUS server?
    If you have friends use your network maybe a captive portal?
