nekrosoft13
- Jan 4, 2005
Looking for 3 or 4TB drives, almost everything acceptable except WD Green.
hdfreedom, looking for internal drives.
OK. So open it up gently, take it out of the case and use it as internal drive. I do it all the time. It's the same drive as what you get here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822178338
just cheaper. And if it breaks, put it back in the case and warranty it.
If that isn't enough, go ahead and buy a more expensive version.
Have you tried eBay? I've been getting 12TB+ for under $200.![]()
do tell
uh how?
