Any fan speed controllers with OFF option?
Discussion in 'Overclocking & Cooling' started by M76, Oct 9, 2019.
  1. M76
    M76 [H]ardForum Junkie
    9,463
    Jun 12, 2012
    I'm looking for a fan speed controller that can actually turn fans off completely if the temp is bellow a certain threshold.
    Are there any out there like that?
  2. rgMekanic
    rgMekanic [H]ard|News Staff Member
    3,938
    May 13, 2013
    I use an NZXT Grid+ on my sig rig, it can do this, I use the feature often since my cooling is overkill as hell lol.
  3. doyll
    doyll Kyle's Thermocouple is HOT
    1,064
    Feb 4, 2012
    Aquaero fan controllers will shut off below selected temp. They are not cheap, but can be programed to do almost anything but was case windows.
  4. dragonstongue
    dragonstongue 2[H]4U
    3,150
    Nov 18, 2008
    you mention as a "reaching" term to say fan controller with an OFF option...
    Sounds like you mean a physical controller of sorts (hardware)
    not (software) such as Open Hardware Monitor (which has a fan speed controller built in for many program versions (I just checked mine..one right before became commercial only version(s)
    I know of many in this regard, most modern GPU default (with varying levels of success) have zero rpm functionality (some require baseline driver(s) others this feature seems to be lowest hardware level.....
    (depending on the goal required.(case fan wires are stupid easy to twine 2 or more off the same lead (preferably 4 pin molex powered)
    link X of the fans to A control port header (3 or 4 pin connection on motherboard proper)
    link other fans to another controller etc etc (watch you NOT go above proper "safe" numbers in terms of watt/volt or amp rating..unless want to cook system in question
    once X link to the fan controller in question, use something like Speedfan or such things, turn down the % there multi-fans off one setting (with some "R neck" way of making it happen...
    I stop there, I believe 2nd poster to the topic at hand likely gave answer that was sought, where my response to the question/issue
  5. VanGoghComplex
    VanGoghComplex [H]ard|Gawd
    1,765
    Apr 5, 2016
  6. doyll
    1,064
    Feb 4, 2012
    Hadn't see that one. Interesting bit of kit.
    I've used aquaero 5 and aquaero 6 and really like them. Just goes to show how poorly I've been following computer evolution the last few years. ;(
    So can each of the four channels have their own temp to rpm curves?
  7. VanGoghComplex
    1,765
    Apr 5, 2016
    From the photos Amazon has (they include some screenshots), it seems like it uses the same Aquasuite software as it's bigger brother. I'd assume you have the same amount of control.
  8. doyll
    1,064
    Feb 4, 2012
    Was just reading up on it and appear to work very much like big brothers. Can use motherboard sensors and/or 4x accessory temp sensors. Only complaint I have agains 5 and 6 is they have so much more potential than most any user will every use.
  9. M76
    9,463
    Jun 12, 2012
    That seems like what I was looking for, although the price is off-putting and it has no sensors included it seems so you need some sort of accessory or how does that work?
  10. VanGoghComplex
    1,765
    Apr 5, 2016
    It can control based on component temp reported by the components if you have it plugged in by USB, but it's also capable of completely standalone operation if you don't want to run the software in the background. If you want to do standalone though you'll need to buy temp sensors. So they're not strictly necessary but you can use them if you want.
  11. doyll
    1,064
    Feb 4, 2012
    What VanGoghComplex said. Uses USB for sensing and for control software package, or you can add sensors for things not available from motherboard, like monitor room temp and a fan flowing air to you when room is hot. :D
  12. M76
    9,463
    Jun 12, 2012
    OK, I ordered az NZXT Grid Plus V3, it supports 3 pin fans as well as pwm fans, it's cheaper and easier to get than the aquacomputer one.
