BigBadBiologist
- Mar 19, 2001
I got a Pentium D 805 to play around with, but my motherboard (sig) has horrible PCIe locks, so I can't even set to 200FSB. With some tweaking of the busses, I can set the FSB up to 179, but no matter what I do, 180 will not POST. I'm 100% sure this is because of the bad locks.
Anyway, from the Pentum D spec sheet, I see this:
BSEL2 BSEL1 BSEL0 FSB Frequency
L L H 133 MHz
L H L 200 MHz
L L L 266 MHz (this is actually from the 900 series spec sheet)
I know that for the 200MHz FSB CPUs, all you have to do is connect BSEL1 to BSEL0 or BSEL2 to force 266 MHz FSB. So is it sufficient to connect BSEL2 to BSEL0 and then insulate BSEL1? Or does BSEL1 need some sort of signal?
L L H 133 MHz
L H L 200 MHz
