I took a pass on the 7xxxk chips as I paid $300 new for my 5820k. At 4.4Ghz it coasts through what I can toss at it single screen gaming, the X99 chipset will be around for a bit too. Should AMD's new chip be all it's hyped to be, and even if not... prices will be dropping on an Intel upgrade path for our x99 mobo's. So unless a newer chipset has somehitn' the x99 lacks, I'd say stand pat.
My2c.
Hey Scoot - When gaming, what are your temps? I was thinking of chaining my setup to 7700K due to the lower TDP.
I'd still go with the 7700k just in case. It's nice to have options. Usually the price difference is small, and the resale value will be much higher on the 7700kSo I've decided to change my setup. Already purchased a new mobo, but having a hard time deciding what cpu to go with. Which CPU would you guys go with? 7700 or 7700k? I don't ever plan to overclock.
92c seems really high for running at stock, even with a low profile cooler.I ended purchasing a 7700k. What generally considered high temps for this chip? On full load, package temp is 92. Is this safe or should I be thinking of getting a cooler? Currently using a noctua low profile heatsink with prolimatech 120 fan.
