Any 40-43" 4k without PWM?
Discussion in 'Displays' started by rive22, Feb 8, 2018.
  1. rive22
    rive22 [H]ardness Supreme
    4,532
    Mar 10, 2004
    TV or Monitor
  2. Commander Shepard
    Commander Shepard Proud Brony
    2,331
    Apr 12, 2016
    Sony 43" X800D (very hard to find) and 43" X800E (still available from Amazon and Crutchfield).
    Sony is releasing some new lines, X850F and X800F, this year. Both will have a 43" model. (y)
    Q-BZ and rive22 like this.
  3. vincentsixtysix
    vincentsixtysix [H]Lite
    76
    Dec 9, 2017
    hopefully an x950F 49 inch version as well VA
    rive22 likes this.
  4. rive22
    4,532
    Mar 10, 2004
    Cheers guys, somehow I get the feeling those are about it yeah? They look pretty good how do you guys like them? Would be for computer use, workstation. The PWM on my 27" 1440p Asus screens, (older ones before their new eye care models) messed my eyes up for a bit and I've been using SunsetScreen for now.
  5. coolhandm3
    coolhandm3 Limp Gawd
    383
    May 28, 2009
    The Sony 43x720e has no pwm, is 4k 4:4:4 has no ABL in graphics picture mode and has 18.7ms lag. It is direct lit vs edge lit and has no vertical banding or dse, less then any tv i have ever used. Comparing it the LG oled c7 and the 43ud79, I prefer the Sony due to superior uniformity vs them for gaming. No banding on any color including light greys. Also it has no issue with the 14 pixels on all sides disappearing when near it like the ud79. The 43ud79 also has horrible vertical banding and comparing it all day today vs the Sony 43x720e, it is no contest, the Sony wins!
    You can get it for $550 pretty much everywhere and It will not disappoint!
    sysdawg and rive22 like this.
  6. Luke M
    Luke M Limp Gawd
    203
    Apr 20, 2016
    You should be aware that not all displays have the same minimum brightness. My Sony TV for example can't get very dim, so is it really better than a pwm display? Not clear...
    rive22 likes this.
  7. rive22
    4,532
    Mar 10, 2004
    How far down can you turn the brightness on those Sony's? I don't need it too dim, as long as it's not blinding bright.
  8. Luke M
    Luke M Limp Gawd
    203
    Apr 20, 2016
    I don't have a measuring tool that would allow me to quantify it, but it's very usable on the minimum setting. (This is a Sony 800D I'm talking about).
    As a completely made up example to illustrate the point, suppose one display is non-pwm and has a minimum brightness of 100 nits. And another display uses pwm, but only below 100 nits. The pwm display would be equal or superior for all uses.
    rive22 likes this.
  9. Later
    Later n00bie
    53
    Jan 30, 2015
    HP has just released the Z43. I don't know if it uses PWM so you better check it out.
    rive22 likes this.
  10. Commander Shepard
    2,331
    Apr 12, 2016
    I've been using a Sony 4K TV for about a year, but have had a few Samsung 4K TVs for monitors, too. I honestly can say PWM never bothered me at all.
    rive22 likes this.
  11. Commander Shepard
    2,331
    Apr 12, 2016
    A couple pics of my X800D at min and max brightness. Not a huge difference.
    [​IMG]
    [​IMG]
    rive22 likes this.
  12. HA5
    HA5 n00bie
    38
    Apr 15, 2015
    Your camera has adjusted the exposure in the two pictures.
    rive22, BearOso and Speedeu4ia like this.
  13. Q-BZ
    Q-BZ Pick your own.....you deserve it.
    16,964
    Sep 28, 2007
    I'm considering this as a potential from the fence. I keep going back and forth with something like this vs the whole high refresh rate g-sync monitor argument with myself.
    rive22 and Commander Shepard like this.
  14. ajrettke33
    ajrettke33 [H]Lite
    101
    Dec 7, 2014
    Dell P4317Q....
    My brother got one (he's a day trader). The software that comes with it allows pretty cool customization for multiple windows/displays. I'm looking at picking one up when they start to drop in price
    rive22 likes this.
  15. neojam
    neojam n00bie
    44
    Aug 3, 2007
    Same.
    Though i think ill be skipping it and wait for a decent 120hz 43incher.
    While XF850 looks interesting and has a native 120Hz panel, it only supports 60Hz inputs...bummer
    rive22 and Q-BZ like this.
  16. rive22
    4,532
    Mar 10, 2004
    I was looking at this before, looks fabulous. But it's PWM.
  17. Q-BZ
    16,964
    Sep 28, 2007
    Overall that Dell isn't a bad value at all if you're in the market for a larger business monitor and PWM doesn't bother you.
    rive22 likes this.
  18. rive22
    4,532
    Mar 10, 2004
    I often do projects around the clock so working nocturnal is frequent where I need to turn the brightness down.
    I never had a prob with PWM at 90%, but then I started doing it 50-60% for a few months, then my eyes became very sensitive to light. To make things worse I would then lower it to like 10%. Totally freaked me out for a while until I saw the eye doc and realized what was going on. Back to using just 100% now with a SunsetScreen app which dims pretty decent without looking like an opacity filter.
    Was reading a bit how some panels have a faster PWM frequency than others, not sure if that helps.
    The Sony looks like a great option, but screens like the Dell and LG that come with those multi window apps are very appealing.
  19. :-)
    :-) n00bie
    37
    Jan 4, 2016
    Wouldn't it be easier/better just reduce brightness in Nvidia Control Panel?
    rive22 likes this.
  20. Commander Shepard
    2,331
    Apr 12, 2016
    You can use an app like WinDivvy on a Sony, Samsung, etc. 4K TV to divide the screen into multiple windows. It works well whenever I use it.
    http://mizage.com/windivvy/
    rive22 likes this.
  21. rive22
    4,532
    Mar 10, 2004
    Fantastic, thanks
    Commander Shepard likes this.
  22. celwin
    celwin Gawd
    865
    Oct 18, 2006
    Is this just a windows manager tool? As in managing multiple open windows from one input. For a second I thought it was software to allow multiple inputs (PBP) on one screen like a true big screen monitor does.
  23. Kdawg
    Kdawg Gawd
    526
    Aug 12, 2017
    all major brand TVs don't have PWM at max brightness setting.
    My TCL 43 has comfortable max brightness around 300nits or a little less, and at this setting, there is no PWM.
    I don't like my screen dim where whites start to look gray.
    Samsung TVs have no pwm as long as you stay above 12/20 brightness.
  24. Commander Shepard
    2,331
    Apr 12, 2016
    Interesting, and it explains why I've never been troubled by PWM on any Samsung I've owned. I keep my brightness settings rather high.
  25. rive22
    4,532
    Mar 10, 2004
    Yeah the more you lower it the worse it gets
  26. rive22
    4,532
    Mar 10, 2004
  27. rive22
    4,532
    Mar 10, 2004
    Was running AMD and they don't let you adjust the brightness anymore, freakin clowns. Popped in a Nvidia and will give it a try.
    Picked up a Samsung 40" on a steal and will try it this way, if anything I could just re-purpose it as another TV if I don't like it.
    But this thing is a mammoth on the desk. Gonna have to see if I can get used to this. Might want to go to a 32". I'll try it for a week and see if I get used to it.
  28. Kdawg
    Kdawg Gawd
    526
    Aug 12, 2017
    I went from 23" to 43". Feels perfect because font size is about the same.
