Antec Skeleton Open Air PC Case
Discussion in 'HardForum Tech News' started by HardOCP News, Sep 18, 2008.
  1. Nenu
    Nenu [H]ardened
    18,893
    Apr 28, 2007
    Its probably safest to put it on a posing shelf out of harms way.
  2. Martyr
    Martyr 2[H]4U
    3,653
    Jan 6, 2006
  3. vengence
    vengence Level capped
    18,471
    Nov 7, 2007
    That could be bad, although this gave me a thought. This case would be GREAT if you felt like doing a full imersion, aka cray blood, setup!
  4. Arvig
    Arvig Gawd
    882
    Dec 30, 2004
    (This was a reply to my liquid comment)
    True I suppose, but like a windowed case I'd assume one would want it at eye level so one can also show off the system. Well assuming one's cable management wasn't crap of course.
    Anyway, it's a neat idea and I don't have any pets or children so those two factors are out. I don't think my house is too dusty..I do have to dust my PC case once in a while but it's never a huge amount. But I'd still be paranoid about liquid even if it is unlikely. And I know me, I'm a klutz. I'd be one of the first to officially baptize my PC in Pepsi if I had this case.
  5. Casus
    Casus Limp Gawd
    296
    Nov 25, 2006
    This..
    and this...
    Honestly, I don't see the big thing about dust floating around, I mean, most cases I know the insides just get caked in dust, you gotta open up the sides and spray your compressed air all over, but then, if you don't have it angled just right (read: Impossible) then you just end up rearranging the dust. At least with this thing you just poof poof and it actually goes away.
  6. ITOAO
    ITOAO Limp Gawd
    176
    Oct 29, 2005
    I will have this.:D
  7. Juggafat
    Juggafat Gawd
    640
    Aug 18, 2008
    I'm gonna be mad if this case costs over $100
  8. capreppy
    capreppy [H]ard|DCer of the Month - April 2009
    3,410
    Jul 4, 2007
    Cable Management would be painful at best. At least in a closed case, you can "hide" cables, but this thing is totally open.
    [​IMG]
  9. MrMike
    MrMike [H]ardness Supreme
    6,521
    Nov 4, 2000
    It's already a ugly ass mess of wires and there aren't even any components in it yet. Blech.
  10. stevedave
    stevedave [H]ardness Supreme
    5,737
    Mar 6, 2007
    If built right that can make some sexy boxes. If Pricepoint is under 100bucks preferable around 70 I'm all over it for my LAN box.
  11. XeenSD
    XeenSD [H]Lite
    126
    Dec 22, 2006
    Wow you think an Armor is bad
    try a mozartTX.
    Huge! and heavy especailly when loaded!
  12. Nenu
    Nenu [H]ardened
    18,893
    Apr 28, 2007
    If you are ok with soldering, you can buy some thinner silver wire, perhaps use multiple braids and make your own method of routing power so that it is either colour matched or harder to see.
  13. Shawnasee
    Shawnasee Gawd
    689
    Jun 24, 2008
    Wall mount for the win.
    This is better for dust because as someone else stated you HAVE to open your box every once in a while to air-dust it out. With this you can do it everyday if you liked without ever having to pull a pin, undo a screw, or having to crawl under your desk.
    Cable management is the only drawback.
    Get out the zip ties.
  14. SyTyJedi
    SyTyJedi n00b
    53
    Aug 1, 2004
    LMAO!
  15. Dekoth
    Dekoth Gawd
    891
    Jul 25, 2006
    I was interested right up until I read this.
    Pity, it is a neat looking case. But I absolutely will not buy anything made of crap steel and plastic. I guess I should have figured, Antec isn't exactly top tier with their cases. Looks like my next case will indeed be another lian-li.
  16. vengence
    18,471
    Nov 7, 2007
    CRS isn't "crap", but the reinforced plastic on the other hand...
  17. Azhar
    Azhar Fixing stupid since 1972
    18,875
    Jan 9, 2001
    I was thinking that if the frames were aluminum, it would bend too easily. It would have to be steel or stiff plastic.
  18. sfsuphysics
    sfsuphysics I don't get it
    13,694
    Jan 14, 2007
    So how is this new vs what I've done quite a few times in the past which is just have my case without the sides on? :D
  19. BallerX
    BallerX [H]ard|Gawd
    1,599
    Jan 17, 2003
    LMAO all the boxes in my house have no side cover. I think I might be able to find one or two of the sides, but for my personal rig, I have no idea where it is.:D I don't really care either.
  20. Chris_B
    Chris_B [H]ardness Supreme
    4,995
    May 29, 2001
    Its basically one of those test bench things with a fan gafertaped onto it. :confused:
  21. Serpico
    Serpico [H]ardForum Junkie
    8,425
    Oct 8, 2000
    I thought one of the points of a case was to shield the components from external interference. I'm also really conscious about noise and making my PCs as silent as possible. This is an interesting idea but not for me.
  22. Nenu
    Nenu [H]ardened
    18,893
    Apr 28, 2007
    What are the noise levels?
  23. Serpico
    8,425
    Oct 8, 2000
    With this Antec case, no idea, but its an easy conclusion to say that with an open case you hear things like PSU fans, HSF fans, etc, much more easily than with a closed case. Aside from having large, slow moving fans for cooling, my PC also has panels with sound insulation material attached. As quiet as all of my internal components are, it is still much louder with the side panel open than when it is all closed up.
    So yeah, something like that isn't really meant for silence freaks like me. :)
  24. Nenu
    Nenu [H]ardened
    18,893
    Apr 28, 2007
    Ah, I thought you knew how loud this new case is.
    I'm giving it the benefit of the doubt until reports come out.
    The large fan isnt going to be any louder than the large top fan in our Antec cases so I'm sure that will be acceptable.
    It may require a switch of hard drives.
    The new 1TB Samsung F1 is practically silent and the WD 640GB AAKS is reported to be just as quiet.
    Both are top performing 7200rpm drives.
    With silent 120mm fans on the gfx card and CPU, this could be a winner!
  25. Serpico
    8,425
    Oct 8, 2000
    Yeah, I don't think I could do with that large fan on the Antec when spinning low. Even with silent 120mm working my on case and on my CPU, its still too loud for me when the door is open. :)
    Then again, I was arguing for silence back when everyone else was using 60mm fans on their CPUs and were totally ok with that. As things get quieter I still want even less noise. With my last build I finally got my PC as quiet as my iMac, and getting rid of my old mirror door G4 Powermac did so much for my sanity (the fans on that thing were so frigging loud).
    I swear, when I build a house I'm making a space separate from my home office for my PC. I don't want to hear squat. :)
    Nice heads up on those drives, btw, I'll have to look into them next time I'm buying a new one.
  26. 9mmx19
    9mmx19 [H]ard|Gawd
    1,556
    Aug 6, 2004
    Personally I dont really like it but I do like that theyre branching out from standard designs.
  27. Dekoth
    Dekoth Gawd
    891
    Jul 25, 2006
    Sorry, I am not a fan of flimsy side panels that flex and bend and an interior that cuts me to shreds. CRS = Crap I will Never buy another CRS case as long as I live.
  28. kooda
    kooda [H]Lite
    79
    May 4, 2007
    I don't really care about the noise/dust issue. My bigger concern is that you don't appear to have any room for a decent HSF on the thing. That hoses it for me.
  29. Jaguar Jim1
    Jaguar Jim1 Limp Gawd
    224
    Jul 21, 2006
    Looks like a really nice Test Bench Frame that adds a little Panache to the Mix. I've been looking at the HSPC PC Workbench but as it has competition from Antec, I will research this further.
  30. Azhar
    18,875
    Jan 9, 2001
    With a massive fan like that on the top of the unit, all you would need is a fat copper heatsink. Who needs another fan? ;)
  31. Jaguar Jim1
    224
    Jul 21, 2006
    The whole Point of this Case, is that if you Need to Build a PC for Benchmarking, or Other Component Testing, this will Facilitate a Rapid Turn around and reduce Overhead by making the Swaps that much easier. For Someone like Brent, and Kyle who Change Gear more often than a lot of you guys they very well could find use for such an item, and maybe Lan Gamers who want some Shazang, to go.
  32. Jaguar Jim1
    224
    Jul 21, 2006
    CRS = Can't Repair Shit?
  33. Axiomatic
    Axiomatic Limp Gawd
    451
    Jun 10, 2004
    This thing is cool but not for the primary PC case. Since I build a new PC about every year this would be a excellent addition to my desk to get the components all overclocked and tested and then once properly set up, moved in to a proper case.
    I may pick one of these up.
  34. swale
    swale Limp Gawd
    274
    Feb 3, 2008
    looks sooo nice anyone have any ideas on watercooling this bad boy??
  35. bob
    bob 2[H]4U
    2,971
    Feb 13, 2002
    Correct, cold rolled steel isnt crap. But, steel at 0.8mm thickness, is a steaming pile of crap. This is just my opinion, but im not interested in a case that has the structural integrity of a sopping wet oragami.
  36. MrHood22
    MrHood22 [H]ardness Supreme
    4,318
    Aug 21, 2007
    Reviews on it should be nice. It seems like it won't be what you want for performance though.
  37. Serpico
    8,425
    Oct 8, 2000
    Same here. Any computer I have has silence as a huge huge priority. That said, lots of people don't seem to mind noise it and it does look pretty cool, so it'll definitely sell.
  38. MrLonghair
    MrLonghair [H]ard|Gawd
    1,764
    Jun 7, 2004
    If it wasn't this pricy I'd jump on a big and a mini once out of prototype stage. I'd have to move stuff around to make space for it and then I would hate how noisy it was and be surprised to find out that the temperatures weren't that much better in an open air chassis.
    But for a spare/guest computer kind of thing with only one fan or completely passive cooling? Yes please.
  39. magoo
    magoo [H]ardForum Junkie
    14,366
    Oct 21, 2004
    dirt magnet.
    hover-craft.
    cat fell in.
    the horror.
  40. bigdogchris
    bigdogchris [H]ard as it Gets
    17,891
    Feb 19, 2008
    Hmm, already trying to figure out where I can make room for this on my desk. Somewhere I don't set drinks that is :eek:
