I'm building a new rig and just got the P180 from Newegg the other day (haven't opened it yet to see if it's the P182 or not though). Anyway, I had settled on an Etasis 850w PSU, but I'm concerned that it might be too deep. Height and Width appears fine, but depth might be a concern (86mm h x 150mm w x 180mm d, or 3.4" x 5.9" x 7.1")
What I want to know is, how much clearance do you have between the back of your PSU and the fan that sits in the PSU bay? How much clearance should I allow for the cables to come out the back and turn up 90°? Although I haven't measured the distance, a friend of mine said it's 8" from the back of the case to the fan blade, which, if I got the Etasis, would leave me about 0.9" from the back of the PSU to the fan blade. Is that enough room?
I suppose I'll find out when I open the case tonight, but is that fan adjustable? In other words, can I move it forward? Or can I buy a slim fan and replace the one there if I need more clearance?
