Antec Aria Build: A64 3K+, Ballistix, 6800U
Dillusion
Specs:
MSI-K8MM-ILSR K8M800 Chipset
A64 3000+ NC 2GHZ
1GB 512x2 Crucial Ballistix 8-2-2-2
BFG 6800 Ultra OC 425/1100
2x120GB WD HD's
Samsung 8X DVD+-RW
Audigy Gold
Antec Aria Case
EDIT: Bought a Fragbox, see that thread. If you still want pics PM me.
Wow...all that stuff is packed in tight. I thought my shuttle was bad :D
Actually, the video card is not as close to the PSU as it looks in that picture... Having the same case myself I can say there is about 1/4" between the two. But those cards and the blower are packed in nice and tight... I hope you are planning on some extra cooling for that case. :) I have a feeling it's going to be hot.
CPU idles at 50c, and 6800U idles at 60c load temps are +-10c for the CPU and +-17c for the GPU.
I may pick up an NV silencer locally today and put it in there. When i installed the comp, i had already put as5 and the HSF on the proc, but i ended up taking the HSF off to fit the PSU and no re-applying AS5, maybe thats why my temps are so high on the CPU, i'll reseat the HSF with some ceramique and maybe do that NVS5 thing, we'll see how i feel when i get out of class.
That's hot... I was idling at 40C with my setup with the sides on the case. With the sides off and watercooling I'm doing 33-34C but I still need fans blowing in because my ram is getting uber-hot.
Yeah im gonna re-try overclocking very soon, need to build up the confidence :D Last time i tried my mobo wouldnt POST and CMOS wouldnt reset for about 5 hours, weird :confused:
A64 3000+ = 145$
MSi K8MM-ILSR = 82$
Zalman CNPS7000LED = 37$
Antec Aria = 97$
2x512Mb Ballistix = 226$
Total Spent: $587
Traded PCi-E X800 PRO + 125$ for AGP8X 6800U
Sold Enermax PSU = 40$
Sold P4 520 = 100$
Sold Abit AG8 = 100$
Sold CM Praetorian Case = 70$
Sold PQI TCCD = 170$
Total Made: 480
587 + 125 = 712$ Spent SubTotal
712$ - 480$ = 232$ Spent Total in the end...
