HardOCP News
[H] News
- Dec 31, 1969
Angry Birds on your physics exam? You might want to start thinking about a new school.
lame question, how do we know the gravitation pull in angry birds world...
...teachers these days...
Well if the initial vertical velocity is 13.05 m/s then it will be up 2m after 2.5 seconds. The horizontal component is obviously 22 m/s, so the launch angle is:
atan(13.05/22) or 30.68 degrees ... yeah? no?
Cmon guys, the teacher is using a familiar icon during a test to add some humour and possibly relive some stress. Props to the prof on this one
in honor of this thread
I would think it would be more along the lines of 60-55 degrees.
xorbe, you are correct.
For a flight time of 2.5 seconds, assuming a level plane, we can make the equation y = v0yt + 1/2gt^2 = (12m-10m). g is -9.8m, and t is 2.5s, so we can simplify to 2.5v0y -4.9(2.5)^2 = 2. So v0y is 13.05m/s. we can also make the equation x = v0xt = 55m, so we know v0x is 22m/s. Angle is arctan(y/x), which is 30.6 degrees
I don't think angry birds is an exact replica of real physics, That being said 0 is straight south right? 45 would be between west and south, so 55-60 would put it on a trajectory to knock the pig off, Not land on it.
I didn't steal anything from the comments page i have just played angry birds a lot.
High school exam? It fits.
From the source's blog:
Ah, the question says relative to the horizontal (so due east is 0 degrees). I think you're saying the same thing except rotated 180 degrees and off the negative vertical axis.
We're looking at this from the side, so north/south/east/west don't really apply.
The universally accepted physics convention is that by the angle, we are referring to angle above the horizontal. That's up and to the right in the diagram.
This is a word problem of a very common physics problem, where you calculate the flight time. You have several values - the distance to target, the flight time, the angle, and the initial velocity. Given any two of those, you can calculate the other two. In this case, it's distance to the target (with a slight twist - the target is elevated 2m) and flight time. The math is for hitting the ground directly at the target. For angry birds, the objective is to hit the target from the side with significant horizontal velocity. This isn't taking that into account, and the problem gets somewhat more complicated. It's merely a way to pique the students' interest in the subject matter.
Exactly...Must be 8th grade school physics.
Depends upon the school I guess, but my niece is starting the 9th grade next year and she's in physics, but it's a conceptual physics course, not mathematical. That question is more a Physics 1 for Physics/Engineering majors type question.
Also, I'm curious where the picture came from, if a student took a picture of his test during an exam that'd worry me as a teacher.
I guess some bright teacher decided using angry bird examples was the only way to keep it interesting to their kids.
To be accurate, you really would need to be given or know the coefficient of drag for the angry bird object as well. to determine the final velocity and initial velocity based on the average velocity (which is given by flight distance and time), then work backward to find the height and angle that produces the flight height given the gravitational accelleration down through out the flight. Basically, I see it as a shortcut way of teaching rudimentary concepts, not real physics, akin to an electronics teacher teaching AC current squared = voltage squared times current squared (which is junior high school level electronics) when in reality you have to use vector algebra and current angle based on impedance...etc... In short, its not physics, it's just a way to keep kids occupied.
Then again, it kept me occupied long enough to write this critique in the first place, so I guess I am not the best one for complaining about it.
Actually, a large part of physics is knowing when to approximate. It's nice to see [H] users are as pretentious as ever, though.Exactly...Must be 8th grade school physics.
