tankman1989
- Aug 21, 2009
I have a galaxy S3 and a HP touchpad with Android 4.4.2 on it. The problem is that the touchpad seems to be in some kind of locked down mode where all I can do is use the Internet and when I try to install something from gog play, the only option I get is for the S3 even though I'm browsing on the HP (I get a notice saying that it is installed yet nothing has been installed on either device).
I just got the Touchpad (used) so IDK if there is something wrong with it.
I also can't access any of the internal storage or do anything except look at the settings. I thought it was because it was stuck in debugging mode, but I made sure that it wasn't. It is running Android 4.4.2 BTW.
