Are you sure you're car supports Android Auto? If it does, you should just be able to open AA on your infotainment screen somewhere after connecting your phone, then it just launches onto all the AA compatible apps that are installed on your phone. If you have Waze installed on your phone, it will show up as one of the apps to launch in AA.
