Overview:
As many of you know, I have a thing for resurrecting older platforms for the fun of it, especially when they have dropped in price a few years later.
Fairly recently I decided to build a dual LGA 771 machine to act as my backup web server, and to run the SMP CPU client.
Before I begin, let me get the following out of the way. I am not building this because it will be extremely fast or efficient. Instead, I am building it because a.) I love hardware, b.) it is dirt cheap, and c.) I don't currently pay for power.
Parts:
Motherboard: MSI Speedster 2 5000X (Manu. Link)
RAM: 2x2 GB ECC DDR2
PSU: Antec Neo Eco 520Watt
As for the rest of it, this will run nekkid until I get a suitable case for it, and I'll end up reusing an old HDD more likely than not.
Cooling:
The tricky part about any LGA 771 build (other than SkullTrail) is cooling! The stock server-style heatsinks are either monstrously loud, overpriced, or they scream like a four-cylinder Ford probe headed through Wolf Creek Pass. As such, I have ordered and will be modifying two non-compatible CPU coolers to fit.
SilenX EFZ-80HA2
According to the Intel CPU Design guides for LGA 771 and 1366, the spacing to the center of the mounting holes on a 771 motherboard are 38.1 mm x 81.28 mm.
771 Design Guide:
1366 Design Guide:
Compare this to the LGA 1366 dimensions, which are 80mm x 80mm, and you can clearly see that there might be some potential for modding the bracket on the above CPU. However, this introduces another problem. As you can see in the photo below, LGA 771 heatsinks are designed to mount to the chassis directly, rather than the board. As such, I purchased the following backplate from eBay for $8 worth of my accumulated eBay bucks: Backplate
Board Photo:
Backplate:
I may end up drilling out the threaded holes and bolting the heatsink on that way, but we will see how things go once the parts arrive.
Questions:
1.) Has anyone else here ever fabricated a custom 771 cooling setup?
2.) Who has numbers regarding the performance increase of SMP with the Ubuntu BFS kernel patches?
Coming Next:
Unboxing photos
CPU cooler modding
Total cost breakdown
Assembly
Benchmarks
More hardware pr0n
Parts:
Picked this up for a song over in FS/T. I am quite happy with the presence of a standard PCI-E X16 slot, among other features.
Pulled from an old 771 Dell PowerEdge server
CPUS: Potentially 2x Intel® Xeon® Processor E5405 @ 2 GHz (quad-core) (Manu. Link)Still waiting to hear the verdict from a certain someone on these...
Cooling:
SilenX EFZ-80HA2
771 Design Guide:
1366 Design Guide:
Board Photo:
Backplate:
Questions:
Coming Next:
Unboxing photos
CPU cooler modding
Assembly
Benchmarks
More hardware pr0n
