_Korruption_
- Aug 22, 2002
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2688
I don't think I'm liking the retention bracket change a lot, but compatibility should trickle over. It'd be easy with the Thermalrights as they just use the P4 bracket with the rear backplate.
