chris89
- Jun 7, 2012
Well for some crazy reason it requires the latest version of Windows 10? It won't install, says it does not support my version of windows.
If you figure out anything cool, don't forget to share!Now how do I install ReLive?
It depends on the laptop in question. In the case of the 2500U HP x360, there has not been much in the way of driver updates since November 2017. Any new games you may play after that likely would not be optimized and have worse performance as a result. There are some games that on ocassion won't even run without an updated driver installed as we have done here.Does this help with getting a few more frames out of games? What does this exactly do? I'm t hinking about buying a Ryzen 2500u laptop and curious on what this is
look through the amd folder in your c drive. I cant remember the exact location but all the components are in there.Now how do I install ReLive?
This is driver updates is all, the latest 18.8.1 works without modding anything & The Radeon Vega 8 is a really solid performer. It was playing Black Mesa at 4k ultra without an issue on the Source Engine.Does this help with getting a few more frames out of games? What does this exactly do? I'm t hinking about buying a Ryzen 2500u laptop and curious on what this is
working fine on everything ive put it on...I am tempted to install 1803 but the last time it totally borked my machine. I wonder if ms has fixed most of the problems?
Sorry to hear that, hopefully you will get things better straightened out when you have the time. Appreciate the heads up.So far absolutely nothing is working right. EVen when I wiped the drivers totally nada the HP june driver package only installs the oct 2017 driver I don't know why. I was able to force install the 18.81 driver but not the ccc.. It looks like I'm going back to 1709. or maybe a scratch install of 1803.... I do have other thing to do with my life....
that's on you. not amds responsibility to support hp products even if it contains amd. just the way it is.By random chance and I don't know how I did it got the 1881 both the correct driver and software installed but again Vulkan crashes so I am restoring back to 1709 where everything was working fine with the latest driver but the 1871 software. There is something in the new Vulkan exts that is not right or incompatible... I should send a bill to AMD for the amount of time I have wasted........
its not new and you have been around long enough that you should know that. nvidia hasn't and isn't always like that either. which is why there are sites like laptopvideo2go hosting modded infs/drivers.Thats your opinion not mine. It getting so companies don't think they have to support what they make. Just take the money and run. I guess that's why Intel and Nvidia are sales leaders they actually support their products even if its in an HP or Asus laptop. We as consumers are being trained to accept substandard quality and support as the norm. And it sounds like you accept that standard as the new norm. Have a good evening.....
Does anyone else have graphical corruption upon resuming sleep or when switching to battery etc? its like flashing corruption
I think its a driver issue with 18.8.1 because the only way to fix it is to use CRU Restart64.exe if anyone needs it here it is.
its not meant for high end gaming, its a mobile apu. try 16x9 and older/lighter gamesI wish this APU had dedicated GDDR5 because it really performs terrible at 1080p on Far Cry 5 & 720p gets on my nerves.
Does anyone else think this Vega 8 is pretty weak? What games do you play that run fine at 1080p?
Placebo or not that's pretty neat. Maybe you'd see some improvement in a benchmark like Cinebench R15 OpenGL or 3DMark Cloudgate.I found a little extra performance, maybe its placebo but by selecting vega 11 graphics in the driver manually in device manager on 18.8.1 & installing 18.8.1 CCC2 you get ReLive that works...
Yeah I'd imagine 8gb of DDR4 could be a limitation for some games considering the GPU and CPU are fighting for the same resources.Nice, me too, I settled on the 18.8.1 vega 8 driver & I found out why it was performing so terribly on Far Cry 5, is because it had Committed over 10GB of ram in pagefile, so I'm out of RAM, I need more RAM to play higher end games, I totally forgot about 8GB not being enough RAM.
So looking, it looks like its about $59 for a 8GB stick of SAMSUNG 2400mhz, making it 12GB laptop, which would help out a lot.
PS - I emailed AMD directly to see if they can release a BIOS update that works since F17 gives "Unknown Command" error as I have F16 BIOS on HP Envy X360. I asked for them to give me the Advanced BIOS Menu key button combo & also to increase the TDP & set a max temp to 84C.
I'm down. Kinda have my doubts that DDR4 will run at those speeds, but I'll cross my fingers. I'd be curious of the timings if nothing else.I'm testing 18.8.2 out, is there any official support for the Vega 8 graphics? Also I have some DDR4-3200 16GB in, want me to test it out guys?!?
bios up to date? is there 3200 on the qvl, did you look?DDR4-3200 doesn't work at all, gave error code 3 long 5 short, and finally got into windows & CPU defaulted to 300mhz and was stuck at 300mhz so its a no go on the Gskill Ripjaws ddr4-3200. So best to stick with SAMSUNG 16gb DDR4=2400 module, making it 20GB total. Also 18.8.2 doesn't work, only 18.8.1 max as of yet
nope forgot this is laptop. 2666 is fastest according to crucial.BIOS is fully up to date, runninig F17 bios which is the latest. I didn't check but it was running at 1200mhz (CPUZ means ddr4-2400) it would of been 1600mhz if it would of run at 3200mhz also the CPU defaulted to 400mhz like x4 multi safe mode or something. Although at first wouldn't even boot with 3 long 5 short CAPS LOCK LED Code being reported said to be CPU not detected from some other forum.
I don't know of any QVL from HP?
https://support.hp.com/us-en/drivers/selfservice/hp-envy-15m-bq100-x360-convertible-pc/16851057
you changed products there. is it the bq100 or the bp111?They think it'll actually run at 2666mhz? I don't know if I'm willing to risk buying the wrong RAM again. Since SAMSUNG is known to work, but Crucial too?
System: HP HP ENVY x360 Convertible 15m-bq1xx
http://www.crucial.com/usa/en/compatible-upgrade-for/HP-Compaq/envy-x360-15m-bp111dx
Only 2400 from what I see. I tested it anyway, only runs at 2400mhz max.
