AMD Threadripper Review List
Discussion in 'AMD Processors' started by Kyle_Bennett, Aug 10, 2017.
  1. Kyle_Bennett
    Kyle_Bennett El Chingón Staff Member
    45,899
    May 18, 1997
    AMD Ryzen Threadripper Reviews
    AMD Ryzen Threadripper 1950X and 1920X CPU Review @ [H]ardOCP
    [​IMG]
    AMD Ryzen Threadripper 1950X and Threadripper 1920X Processor Review @ Legit Reviews
    AMD Ryzen Threadripper 1950X And 1920X Review @ Hot Hardware
    The AMD Ryzen Threadripper 1950X and 1920X Review @ PCPer
    AMD Ryzen Threadripper 1920X & 1950X Review @ Hardware Canucks
    AMD Ryzen Threadripper 1950X @ Guru 3D
    AMD Ryzen Threadripper 1920X review @ Guru 3D
    AMD Ryzen Threadripper 1950X Review – The HEDT King? @ Vortez
    AMD Ryzen Threadripper 1950X & 1920X Review @ Tech Spot
    Review: AMD Ryzen Threadripper 1950X and 1920X @ Hexus
    Nihilus1 likes this.
  2. Nihilus1
    Nihilus1 Limp Gawd
    443
    Jun 7, 2015
    Nice review at Guru3d.
    "** Right before testing Ryzen 3 and Threadripper a new game patch was issued and kicked in. Ryzen perf is going up and up and up and up with each new patch (great to see). We still need to re-test Ryzen series 5 and 7 but as you can see, the immense gap has pretty much been closed with merely game engine optimizations."
    So much for glued together latency.
  3. Nihilus1
    Nihilus1 Limp Gawd
    443
    Jun 7, 2015
    Most of these reviewers are hitting 4.0 ghz on the cpu which is great. More impressive is that they are also getting 3200 mhz on the Ram - some with cas 14!
    Kyle_Bennett likes this.
  4. Pieter3dnow
    Pieter3dnow [H]ardness Supreme
    4,809
    Jul 29, 2009
    JustReason likes this.
  5. Trimlock
    Trimlock [H]ardForum Junkie
    14,178
    Sep 23, 2005
    It looks like x399 is coming out more mature than the x299 platform.
  6. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    19,319
    Sep 13, 2008
    ever since the 1.0.0.6 update getting 3200 on samsung B dies hasn't been much of an issue.. pretty much all cas 14 ram are sam B some 15 are mixed between B/D and i think hynix E while cas 16 are typically hynix M and still have issues. hopefully they're able to figure out the hynix M problems so i can run mine at their rated 3200 clock.
  7. realworld
    realworld Limp Gawd
    214
    Apr 24, 2016
